08-24-2010, 10:53 AM | #1 |
PROJECT 7DEUCE
Need some measurements please..
I am looking to reinstall my blazer side panels and the screw holes for the side panel mounts were welded up at some point can someone give me a rough measurement as to where drill the holes?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-24-2010, 01:37 PM | #2 |
Re: Need some measurements please..
I'll try to get some tonight, 1 am EST. if someone doesn't respond sooner
08-24-2010, 03:12 PM | #3 |
PROJECT 7DEUCE
Cool, Ill be waiting.
08-25-2010, 01:45 AM | #4 |
OK, first from the back of the 'B' post
first set first hole 14 3/16", second hole 18 11/16", both are 4 1/8" down from the indent. Alittle hard to get that demension as it has a convex curve. If you need it to be exact, I'll come off another plane now, off of the front of the post that houses your taillites second set first hole 15 3/16", second hole 19 1/2". Same distance down Might be difficult to drill the same hole that was welded up, as it might be hardened from the welding If it doesn't make sense, I'll try to take pics. We all like pics
08-25-2010, 11:49 AM | #5 |
PROJECT 7DEUCE
Thanks that is just what I needed...
09-03-2010, 11:38 PM | #6 |
PROJECT 7DEUCE
Ok so I striped down the inner bedside metal and there are no holes that I can see. If the blazer was not ordered with the side panels would there be no holes?
09-04-2010, 08:46 AM | #7 |
I think you are right, my 71 did not have the side panels originally. No mounts or holes.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
