Old 08-26-2010, 10:43 AM   #1
Illgill
Where can I find? 73 heater control w/ac
I need to find a 73 heater control with a/c for my truck. The slide for the temp has frozen and will no longer move. I check LMC and they carry only the w/o ac. Any ideas.
73 Chevy K20 longbed 350 trans m20
Illgill is offline   Reply With Quote
Old 08-26-2010, 01:05 PM   #2
Adams74Chevy
Adams74Chevy's Avatar
Re: Where can I find? 73 heater control w/ac
Did you try soaking it with WD-40, etc?
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 08-26-2010, 03:04 PM   #3
tucsonjwt
Classic parts has heater/AC control for 74-80 for $105 + S&H, don't know about 73.
Here is a tip - I worked in a GM plant that made these heater control assemblies a long time ago, and I can tell you that many of the controls would stick when coming off the assembly line. There was a rework person (or two) who would work on the levers with a screwdriver, hammer, channel locks, and lithium grease to "adjust" these controls. Needless to say, these are not precision manufactured items. So, I would try to coax the levers first. Just be careful, because these are just spot welded and the welds can break easily. My guess is that the lever on yours jammed due to age and lack of grease, then bent when moved. The levers are just very inexpensive stamped metal. You should be able to carefully "unbend" it. On my control, a slide lever end snapped off just below the knob, so I replaced the whole assembly.
tucsonjwt is offline   Reply With Quote
Old 08-26-2010, 03:52 PM   #4
Orange77
Orange77's Avatar
if your looking to find one with the ac option check brothers i think they had one or junk yard man...
Orange77 is offline   Reply With Quote
