Old 08-29-2010, 12:55 PM   #1
ubtripn
ubtripn's Avatar
350 Timing setting
Hi everyone,
I have a 68 Chevy truck that has a 70's 350 in it. The only non-stock item appears to be the 650 Edlebrock carb. Does anybody know in general what I should se the timing at? I am currently looking for the engine ID. Thanks.
ubtripn is offline   Reply With Quote
Old 08-29-2010, 02:02 PM   #2
Lee H
Lee H's Avatar
Re: 350 Timing setting
Assuming your distributor and both the vacuum and mechanical advance are in good working order I'd start by disconnecting the vacuum hose to the distributor, set the timing at 12 degrees advance. That should result in about 32 degrees advance at 2800 - 3000 RPMs. Reconnect the vacuum hose and test drive. If it pings at drop it by 2 degrees and recheck. This will get you in the ball park and you can fine tune fron there.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-29-2010, 02:13 PM   #3
ubtripn
ubtripn's Avatar
Again, thank you for all of the advice.
