Sad Sad Day
Unfortunately the day has come where I need to outsource work on my truck. I am need someone to finish wiring in my bladed fusebox that I acquired through EZ Wiring (Big mistake). Also I have broken the alternator bolt and ez out bit inside the block so I'm thinking a machinist is in order. Anyone in the Fort Worth, Crowley, Burleson area who comes highly recommended for these issues? Thx in advance
2006 Crew cab Z71 1972 Short Wide Step (under construction) |
Old Skool Club
![]() Join Date: Jun 2001
Re: Sad Sad Day
Sorry for your troubles.
Your post makes me think that my OEM-type wiring harness from M&H was a good thing to do, if the blade-type is making your job an "issue". You'd think that anything designed to be a user-friendly replacement would be a virtual plug-n-play type of experience.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: Sad Sad Day
No doubt. The product looks quality and solid but not user friendly like a Painless or other front running brand. Live and learn I guess...
#4 | |
Still Learning
Re: Sad Sad Day
Re: Sad Sad Day
None of the you make it kits are easy. Alot of people use painless, but the experience I had with one on a guy's truck was not painless in fact it was plain aggrevating- anytime you have buy a new harness and have to use parts off a used harness in order for everything to hook up and work correctly. The only time, in my opinion, one should buy one of those kits iis if they are doing a full out custom with computer control and power everything. If you want a stock type harness these are not the way to go- M&H or American Auto Wire offer current spec updated wires and absolute plug and play install, 2 hours give or take and you can do a entire truck and be driving down the road. EZ, painful and the other make your own harnesses will be much more time involved, plus cutting the firewall to fit, cutting wires, grouping and covering in some form or fashion. yellow and blue crimp on connectors are not my idea of a nice set up. Again my opinion- and if you install "correctly" you will have much more invested in supplies than if you had bought a pre made harness.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Re: Sad Sad Day
I would agree that for a bone stock application that buying an OEM style harness is the way to go.
However, that being said, I have used (2) Painless Kits and had no problems with either of them. I did contact their tech. support people a few times, and they were very courteous and helpful. The fact that you need to make your own terminations allows you to route the wires in a very organized manner and then cut them to fit. Also everthing that was needed was supplied by Painless, except a crimping tool. I realy have nothing but accolades for Painless, good product and good people. The insight that Chuck gives about EZ Wiring is very helpful, thanks Chuck. I had considered buying an EZ Wiring harness for my 65 C10 to save a few bucks, I think I will stick with Painless. I plan to move the fuse box into my console for ease of access and I have a lot of custom, non stock compopnents, therefore an OEM style won't work. Thanks again Chuck for your post. Last edited by lakeroadster; 08-30-2010 at 06:14 PM. |
One of my kids. Cute eh?
Re: Sad Sad Day
So....what is the problem with the EZ Wiring harness? I used a universal one in my CJ-7 Jeep and I got it all figured out on my own except for the light switch. A friend of mine got that figured out.
I had to reuse one part of the harness for the windshield wiper and another part for the heater. Otherwise, everything else was on the EZ. I was going to wire my 71 Chevy with the same kit. Considering I hate working on electrical, I still got it figured out. Was actually sort of fun now that I think about it. Mike
If a kid asks where rain comes from, I think a cute thing to tell him is “God is crying.” And if he asks why God is crying, another cute thing to tell him is “Probably because of something you did. John 3:16 2006 Chevy HHR 2000 Dodge Durango 1985 Jeep CJ-7 1970 Chevy Pickup |
Old Skool Club
Re: Sad Sad Day
Let's face it. When it comes to electrical systems and wiring issues, nothing can be a more fearsome task to some people. For others, it's a walk in the park. If you are one who has some trepidation regarding wiring/electrical issues, you need to consider the best possible "plug-n-play" wiring harnesses. It isn't that I'm uncomfortable with wiring....I bought the M&H harnesses from Wes at Classic Heartbeat. I don't regret it. As for the old harnesses.... they're not destroyed. Everything was unplugged and unattached properly. It's just old wiring and there's too much at risk to spend megabux on a vehicle and then expect a 40+ year old wiring system to function w/o any worries.
Re: Sad Sad Day
Sounds like you need to put some distance between you and your truck (That Way you dont brake it anymore). Sorry to hear about the problems your having. If I were closer I would help you out with your Electrical Problems as I was an Electrician for 25 Years working on Airplanes. Remember you have 12VDC and a ground in most cases and if you have a lighted probe and you brake it down to power and ground it becomes pretty easy that is if you know how to read a schematic or a Wiring Diagram. Anyway good luck with your problems, I broke an easy out in a Toyota I had it was one of the bolts holding the Thermostat cover in place and I went to the store and got a C Clamp and clamped it. I sold it like that at 200K miles. I really hate braking off easy outs.
JRBECK64 |
#10 | |
![]() Join Date: Feb 2001
Re: Sad Sad Day
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Still Learning
Re: Sad Sad Day
I offered to fix it if he sends it to me, flat rate priority both ways and I'll fix it for free
#12 | ||
Re: Sad Sad Day
Unless I am reading it wrong... Mike
#13 | |
Still Learning
Re: Sad Sad Day
I'm not the best with reading comprehension....my bad. Well, in that case sorry but you can't ship the engine. Duh! I would help if I was closer. Still have your local class a welder tig weld a washer or bolt to the ezout first, get it out of the way if possible, then try the bolt itself. You can use a heat shrink heater gun to heat the area around the stud to help free it up. Maybe penetrating oil? good luck! sorry I can't read. ![]() |
![]() Join Date: May 2006
Re: Sad Sad Day
3 possibilities:
Sharp chisel, ez out's are brittle...wear safety glasses and goggles carbide drill bit grinding stone on a dremmel, you'll go thru lots of stones to get past the ez out it's already broke, so the worst that can happen you will have to drill and tap the hole one size larger...once you get the ez out out
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-31-2010 at 01:00 AM. |
#15 |
Re: Sad Sad Day
A pencil grinder with a 1/8" carbide burr will get through the EZ-out (not easily, but not terribly difficult either)........but keep in mind that in a through hole, lots of chips and chunks will end up inside the block at this point. You may need to pull the pan afterward to keep the stuff from circulating. You may be able to shatter the EZ-out to get it if you can't cut through it.....but you may just drive it deeper.......it's somewhat of a gamble either way. If you are wiling to waste a steel grinding burr or drill bit, you can try to "cut" the EZ-out with the steel burr and keep going 'til they both turn red/orange.........THEN shatter the EZ-out after you've work-hardened it. The danger here is walking off-center while you're pushing on the burr or drill and wiping out the threads of the bolt hole...........so don't really recommend it. I can try to help talk you through it if you want to attempt to get the EZ-out out and the bolt out......but I'm going to need more information so I know where you are and how much "wiggle room" you have to work with. If you have enough room between the EZ-out and the bolt threads....and a small enough burr....you can grind around the EZ-out rather than having to grind through it. Then you're simply left with the stuck bolt you started with and a slightly bigger hole in it. Penetrating oil, heat, etc. usually help. (you probably already knew that) If you end up with damaged threads, you can still heli-coil most bolt holes on the block and be OK. For what it's worth......I'm a machinist for an airline and I end up removing WAY too many broken bolts and studs in a week's time. (as well as broken extractors and taps too.) |
#16 |
![]() Join Date: Aug 2004
Re: Sad Sad Day
Since you are on Crowley, go East on 1187 past Rendon "S" curves, Mabry Automotive, see Trey if he cant do it he can tell you where to get it done. Phone is 817-463-1155. this is for the broken stud, not sure if he would want to do the wiring harness.
I used that and my dad used that ( EZ Wiring) on his, what a beating, but I think because there was many more wires than what is needed and it is a universal, but they work and they are safer than the 40+yo original.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#17 |
Re: Sad Sad Day
Yep it's the long bolt into the block. it's broken 1/8" into the block so nothing to grab onto. The ez out snapped flush as well. I am thinking I need a machinist with some special angle head drill or such. I have parts to trade or cash if anyone local to Fort Worth can help.
The harness is just not user friendly in that you have to build it up with your own connections which to me is a pain. I am so frustrated I had to walk away. I will pay for someone to walk me through it. Lastly this is the best ( without a doubt ) resource for truck fans. I have never been disappointed by the support here. You guys are GREAT! Thx so much...
#18 |
Re: Sad Sad Day
ive installed both painless and ez wiring and there isn't a nickel's worth of difference other than painless being about 3 times more expensive ...
