Old 08-31-2010, 12:15 PM   #1
Pro Performance
Pro Performance's Avatar
Gas Tanks
I have an '84 chevy short bed with factory dual tanks. Are these interchangeable from driver to passenger side?
My drivers side has a leak, so I want to move the passenger side tank over and get rid of the bad one. I will then fill the passenger side door.
Pro Performance is offline   Reply With Quote
Old 08-31-2010, 02:58 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: Gas Tanks
Tanks are interchangeable from side to side but sending units are not so you have to switch that also
ont_guy_38 is offline   Reply With Quote
Old 08-31-2010, 04:07 PM   #3
Pro Performance
Re: Gas Tanks
Thanks for the info.
Old 08-31-2010, 05:09 PM   #4
68 TT
Still plays with trucks
68 TT's Avatar
Re: Gas Tanks
The tanks are cheap new. It might not be worth the headache of pulling the passenger side tank off, swapping out the sender & reworking the plumbing to eliminate the passenger side tank. The lines are a pain in the butt to work with.
What about leaving it alone and just running on the passenger side tank for a while? You may find that a single 16-gallon tank is no fun at all when you have to stop at the gas station twice as often.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-31-2010, 05:34 PM   #5
ont_guy_38
ont_guy_38's Avatar
Re: Gas Tanks
I was going to mention that also but i assumed he had his reasons for doing it.My truck has duals doors and only one tank , I just figuired it wasn't worth the trouble of closing it up and I think only one person has ever noticed I don't have dual tanks
Old 08-31-2010, 05:46 PM   #6
BigRed76
BigRed76's Avatar
Re: Gas Tanks
My '76 shortbed has only one 16 gallon tank, and frankly it sucks i get decent gas mileage and it seems like im at the gas station way too often. I would love to have dual tanks but dont wanna go through the hassle of the lines.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 08-31-2010, 05:53 PM   #7
68 TT
68 TT's Avatar
Re: Gas Tanks
Now imagine if you got 7 mpg like I do. I'm just glad I don't have to drive that far.
Old 08-31-2010, 05:18 PM   #8
Pro Performance
Re: Gas Tanks
True.... I can maybe find a used tank on Craigslist also. It would keep me from having to fill the other gas door too.
Old 08-31-2010, 06:54 PM   #9
wyattglock
wyattglock's Avatar
Re: Gas Tanks
If you are going to go to one tank, why not try and put a Blazer tank in the rear? I know that interferes with the spare, but you can get a single tank with a larger capacity that way. I was thinking about doing something like that with the filler neck coming out behind the license plate.
wyattglock is offline   Reply With Quote
Old 08-31-2010, 07:18 PM   #10
68 TT
68 TT's Avatar
Re: Gas Tanks
Good idea on using the Blazer tank but you would have to mount the Blazer tank really low to fill from behind the license plate. The top of the tank is above the top of the frame rail in stock configuration. That would put the filler above the bumper if run straight across. The filler neck also points to the passenger side and is located close to the edge so it would be hard to plumb it to the center rear.
Standard capacity is 31 gallons so it is pretty much the same as dual tanks on a short bed.
Old 08-31-2010, 09:41 PM   #11
wyattglock
wyattglock's Avatar
Re: Gas Tanks
Good point about the filler neck, I hadn't thought that far into yet. I suppose it could be customized to work with a fuel door installed in the right location on the bedside, and then fill in the old ones. However, with that much work involved, it would probably be easier to repair the existing tank.
Old 08-31-2010, 11:40 PM   #12
Scottsdale Doc
Re: Gas Tanks
i just brought a new fuel tank for 85 swb.
Dorman 16 gal including lock nut and o-ring from parts geek $110.98
They seemed to have the best price with low cost shipping.
Scottsdale Doc is offline   Reply With Quote
Old 09-01-2010, 09:10 AM   #13
xrcr
Re: Gas Tanks
I have a drivers side great shape w/sending unit and whatever else you need on an 83 1/2 ton chassis I can't get rid of. Before it goes to scrap heaven I need to cut the tank in half or they won't take it. You can have it for the cost of shipping, however iIhave never tried to ship a "used" gas tank across the country so that might be a pain. PM if it's worth it to you.
xrcr is offline   Reply With Quote
Old 09-01-2010, 11:07 AM   #14
Pro Performance
Re: Gas Tanks
PM Sent. Thanks.
It sounds like either way, a new (or used) gas tank would be the way to go.
Old 09-01-2010, 11:58 AM   #15
wyattglock
wyattglock's Avatar
Re: Gas Tanks
I bought a used gas tank from a friend that was parting out a truck for $20 with the straps and sending unit. It was a lot cheaper than a new tank, you just have to make sure it's good and clean before you install it.
