best palce to get 454 radiator?
where is the best place to get a 454 radiator for our trucks? and what all do i have to replace to make it work? upper/lower brackets, shroud, ect?
thanks
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
Check online for radiators, think I paid $169 for mine. Then your gonna need the rubber feet(top and bottom) and top brackets. Finish it off with a metal top thingy and a new shroud. I got the metal thingy and shroud from Cheyenne PU parts and thats it! Everything bolts in to factory holes.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
I paid around $200 (maybe $211) for a 4-row from NAPA, I believe the computer reads 454, or 350 4-row replacement. Anyway the brand is Modine and is supposed to have a life-time warranty again leaks or defects. I have had it for about a year, maybe 1-1/2 years, cant remember. No plastic on this one. Hope thats helps some. If you need a part number let me know, I still have the receipt out in my truck.
PS: Make me an offer on the shroud (one piece), its like new. I bought it when I swapped engines about 3.5 years ago. It was on the truck for about 6 months, then removed for electric fan. I can email pictures if needed, I think it was about $60 new from GM.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
where can i get the upper/lower brackets and boots? and how much do they run?
BeWarE tHe eViL CrAnkTOe!
Im thinking of doing the 4 core upgrade too!
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
Yeah no plastic ends.
I had the guy check both 4-row replacement (for 350) and 454 4-row (back when I bough it). He said they were the same part number. Exact cost of radiator was $208.19 Part Number is = 730 Item Number (manufacturer) = MO So it might be something like = MO730 The receipt is kinda wierd, but under part number it just says "730" Description reads = Radiator 350/RI 5.7L 350 not sure what thats all about, but thought you may want to know. Found this online: http://www.napaonline.com/cgi-bin/nc...8&prmenbr=5806
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 02-24-2003 at 04:12 PM. |
You don't need any lower brackets just uppers. You'll need the four row radiator rubber feet pads(4). I went to my nearest GM dealer and got them. It's easy just tell them you have a Suburban with a 454 and order those part numbers.
BAD BOW-Silverado XST
G man, have you used there rads. will they hold up to the desert heat with the A/C on in traffic??
I know the price is a little high, but the modine is a good radiator and holds up very well so far.
I'm back with 2nd truck!
I agree with G. I got a radiator from Radiators.com. No worries whatsoever. I got mine for $189? 4 row delivered same day. Lifetime warranty!! All metal and brand new.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
solidaxel,
They should hold up. I bought one for my Dakota. I was surprised when it arrived. It was a Modine radiator. No problem on my end. Sorry no experience with a radiator for our trucks. I'm going to use an aluminum core. ![]() |
Insert Witty Text Here
When I was looking for a new one for my truck, all the places charged about the same and carried the same brand. I went with Auto Zone, which I really don't like, because they have the most stores.
If the products are otherwise the same, buy it from the place where you are most likely to be a ble to take it back to under the lifetime warranty. Around here, there's an Auto Zone on just about every street corner. Slonaker |
