Old 08-31-2010, 10:21 PM   #1
Mattman2010
Mattman2010's Avatar
Vacuum Questions and A/C Questions
I have a 1980 K10, It had a 250 in it, and I am now trying to put a 350 out of a 1980 K20 in it.
I have the vacuum line from the TH350, and I am not sure where the hose is suppose to go to.
The 350 I am putting it in, did not have a TH350 behind it, it had a SM465 so I am not sure where the vacuum line is suppost to go. Someone was talking about a vacuum port behind the carb.
This one:
It had about a 2 foot vacuum hose that I think hooked up to this black thing that was mounted on the firewall.
What is this thing? Will hooking the transmission up to that vacuum port behind the carb work, or does that black thing need to be hooked up?
Now about the A/C will the compressor off of the 250 work with the 350 if I had all of the right brackets, and all of the right hoses? I have been trying to save it because I was hoping that I could use it on the 350 when I get all of the A/C brackets. Also what would I need to change on it to change it to the new R134a freeon?
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 08-31-2010, 10:49 PM   #2
menace121978
menace121978's Avatar
Re: Vacuum Questions and A/C Questions
you pretty much got it figured. the tranny line goes to the manifold as you have pictured. the black ball is for the a/c. it gets manifold vacuum as well. the big nipple is manifold vacuum and the small one goes in the cab to the a/c switch on the back of the a/c cluster. hope it makes sense
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-01-2010, 03:49 PM   #3
Mattman2010
Thanks for the help, I just want to be able to get the vacuum lines all hooked up so I can start the truck in a week or two. It doesn't have the brackets for the A/C so for now the A/C stuff isnt getting hooked back up.
Build Thread
Build Thread
Thread
