Grandpa in the rustmobile...
HELP! out line to carb from fuel pump leaking!
OK, older fuel pump, older hard line (older as in from my old engine but parts were no more than 1 1/2 years old..
No leaks on old motor Take it off and re install on my new motor and it leaks..so I get new line and fuel pump, bend it up (3/8 with parts store double flare) put it on with a TID BIT of thread sealer (blue) and tighten it up and it STILL leaks So what gives lol this is a pita little bug.. ![]() thanks in advance folks edit, its leaking at the screw in fiting
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 Last edited by oldblue1968chevy; 09-01-2010 at 06:49 PM. |
![]() Join Date: Sep 2005
Re: HELP! out line to carb from fuel pump leaking!
shouldn't need any kind aof sealant on teh trends try to loosen and tighten a few time to seat the flare
Well, I was at desperate measures, i'll wire wheel it all off, so tighten,loosen, tighten loosen etc and then tighten it down? I'll try it thanks...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
