Old 09-01-2010, 10:14 PM   #1
Andy4639
Old member
Andy4639's Avatar
Lightbulb New Power steering
OK,
this thread addresses some issues with brackets and such for differant years.
http://67-72chevytrucks.com/vboard/s...d.php?t=419306
I have the stock 71 power steering. I want to know what I would need to change it over to a later model with better feel. Is the price differance worth the swap also. O-riley auto parts has the factory 71 stuff. Is a 73 up cheaper you think? I guess I need to check on it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-02-2010, 06:27 PM   #2
Andy4639
Old member
Andy4639's Avatar
Question Re: New Power steering
No one can tell me they haven't changed to a newer sector!
Old 09-02-2010, 07:19 PM   #3
Tkmadone
I believe the 77-78 steering boxes have the same hose fittings as ours do and they are variable ratio as well.
Tkmadone is offline   Reply With Quote
Old 09-02-2010, 07:54 PM   #4
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: New Power steering
Thanks, are they direct replacements? I don't mind the steering now but if the money is basicley the same and I can get a better sector I think it would be worth it. Mine is going to need replacing very soon as in the next couple of weeks so I may check on it. Thanks again.
Old 09-02-2010, 08:50 PM   #5
Tkmadone
Yes, they are a direct bolt in.
Old 09-02-2010, 10:10 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: New Power steering
Cool I have to check on it, thanks!
Old 09-03-2010, 07:08 PM   #7
BHyatt
I swapped my Steering Gear for one out of an '85 and it was a direct bolt up. I also pulled and used the pump and hoses. The pump sets high in the engine bay unlike the old style. I had a leaky pump and hoses so it worked for me. The Variable assist made a HUGE difference in how my truck drives. I pulled all of these parts used for $47.00
BHyatt is offline   Reply With Quote
