changing oil after coolant contamination
Hello guys,
I was just wondering if theres any special procedures i should do when changing my oil after getting coolant mixed in with it. I was thinking of filling her up a couple times with some cheap generic oil, run it for a few minutes. Then drain for a couple hours each time. Sounds good?? any other idea?? thanks! |
Re: changing oil after coolant contamination
Thats what i would do, i never had a problem with getting coolant in the oil but as long as you get the coolant/oil out for the most part and fill it up flush it a few times i cant see that being a bad idea. I think one of the board members did this, i remember reading it not too long ago. Ive heard of people that take there quads after they sink them in the lake do this and never had a problem with it.
Gone to greener pastures
![]() Join Date: May 2007
How much coolant & how did it get in there?
If it wasn't a ton of coolant, I'd probably just leave the drain plug out overnight; then add oil & a new filter. Run the motor to get the oil good & hot so you evaporate any water/coolant that might still be in there.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 09-02-2010 at 01:18 AM. |
intake gasket leak, ill give it a whirl
I am a Referee of life.
My 67 was in a flood once.Water above the bottom of the windows.I pulled the drain plug and let the water run out.When it went to oil I added a couple quarts and got it warmed up good.Took more time to get the electrical dry enough to run.Then I changed the oil and filter.Ran the truck another 40,000 mi or so before I did anything else but maint on it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: May 2009
I used Seafoam in an engine in the same situation, seemed to clean up the coolant quite well.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
Same. And a new filter of course.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
