Old 09-02-2010, 02:53 PM   #1
bmfpeterson
bmfpeterson's Avatar
What headers to use with bags?
I know this isnt a suspension question but thought I would ask the suspension guys.
I have a 71 stock arms and bags with 3'' spindles and trailing arms with bags in the rear. I just bought some full length headers and they hang down 3-4"s bellow the frame rail. I have a sbc with maybe 450 hp. I want to have the most performance I can get out of my headers but I want to know what you guys with low trucks run. Here is a pic of the truck aired out looking at the headers. maybe 1/2'' of clearance?
any help is greatly appreciated!
bmfpeterson is offline   Reply With Quote
Old 09-02-2010, 03:10 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: What headers to use with bags?
Doug Thorley makes some nice headers that don't hang below the frame. I'm not sure what the part number is though....
Hart_Rod is offline   Reply With Quote
Old 09-02-2010, 03:21 PM   #3
bmfpeterson
Im on it! they look pretty nice!
Old 09-05-2010, 04:28 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
D-310c sbc
pass side
Old 09-05-2010, 12:50 AM   #5
firedog
firedog's Avatar
i have the same prob my exhaust guy turned the pipe up from the headers above the tranny cross member then cut holes in the trailing arm crossmember when my truck is aired out it just barely sits on the header with all the weight on my tubular a-arms
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 09-05-2010, 02:03 AM   #6
bill c
bill c's Avatar
i went with 68 camaro headers for my big block. made some mount mod's but not that bad.
bill c is offline   Reply With Quote
Old 09-05-2010, 02:58 PM   #7
Shane
Shane's Avatar
i'm using 3/4 length dynomax headers for chevelle/malibu ... simply bolt on and go ... no mods.
Shane is offline   Reply With Quote
Old 09-05-2010, 03:23 PM   #8
Rochlow
Heddman shorty headers here.
Rochlow is offline   Reply With Quote
Old 09-05-2010, 03:33 PM   #9
bill c
bill c's Avatar
is it on a small block or big block.?
Old 09-05-2010, 07:14 PM   #10
Shane
Shane's Avatar
small block ...
Old 09-05-2010, 08:22 PM   #11
Hart_Rod
Hart_Rod's Avatar
small block ...
What size are the primaries and collectors Shane?
Old 09-06-2010, 09:06 AM   #12
Shane
Shane's Avatar
the primaries are 1 1/2" and the collectors are 2 1/2" ... fairly small, but do fine on a stock to mild motor ... they also won't fit angle-plug heads.
Old 09-06-2010, 02:16 PM   #13
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
also the 3/4 for the 87 trucks
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-06-2010, 04:19 PM   #14
Shane
Shane's Avatar
nope. different header.
Old 09-07-2010, 10:39 PM   #15
PipsC10
PipsC10's Avatar
Sanderson headers, got them from early classic enterprises
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 09-05-2010, 09:37 PM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
I also know these work, the flanges were kinda thin 5/16''
Exhaust
Manufacturer's Part Number H8021-1
Part Type Headers
Product Line Patriot Clippster Headers
Summit Racing Part Number PTE-H8021-1
Header Style Mid-length
Header Material Steel
Header Finish Ceramic coated
Primary Tube Diameter (in) 1 5/8 in.
Collector Attachment 3-bolt flange
Collector Diameter 3.000 in.
Tuned No
Primary Tube Gauge 16-gauge
Cylinder Head Port Shape Round
Flange Style Standard
Flange Thickness (in) 5/16 in.
Bolts/Studs Included Yes
Only pic i can find with the patriots
Old 09-09-2010, 10:35 PM   #17
denny5625
denny5625's Avatar
I have a 71 2wd with a big block and I used Sanderson headers. They tuck real nice.
denny5625 is offline   Reply With Quote
Old 09-10-2010, 03:23 PM   #18
Jparks
Jparks's Avatar
Rochlow, you got a part # on those hedman's and do they stick below the frame at all? Pips or Denny, those sanderson's stick below the frame?
72 SWB - Porterbuilt Front/Rear, 22's, 496bbc - "Outkast"
68 Stepside - Porterbuilt Coilover Chassis, 22's, LS3 - "Badfinger"
Jparks is offline   Reply With Quote
Old 09-10-2010, 09:24 PM   #19
PipsC10
PipsC10's Avatar
No they do not, they market them for lowered trucks. They dont even come close.
Old 09-11-2010, 11:19 AM   #20
dznucks
dznucks's Avatar
this is what i am running......
http://www.edelbrock.com/automotive_...treetrod.shtml
dznucks is offline   Reply With Quote
Old 09-11-2010, 09:28 PM   #21
Rochlow
http://www.summitracing.com/parts/HED-69648/
Old 09-12-2010, 11:28 AM   #22
Lee H
Lee H's Avatar
Originally Posted by Rochlow View Post
Are you using these with a C10? Info on summit says OK for C20 & C30, no reference to C10. Thanks,
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-12-2010, 11:44 AM   #23
Rochlow
Yup.. I had to clearance the frame in some areas, but it seems to work..
Old 09-12-2010, 11:55 AM   #24
Lee H
Lee H's Avatar
Any chance you could post a pic of the clearancing? Thanks,
Old 09-12-2010, 11:46 AM   #25
hotrodhomi
hotrodhomi's Avatar
I used hedman ceramic coated shorties, but I didn't like them. I replaced them with 2.5" corvette ram horns.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
