Old 09-06-2010, 10:49 PM   #1
Robert Bergstrom
Robert Bergstrom's Avatar
Spring compression
I am upgrading to the 2-1/2" drop spindles and am keeping the stock springs. I have rented a few spring compressors from local auto parts stores. They work but the bolt in the middle is too long and I cannot get it out of the middle without compressing it again to get it out. Should I be looking for a shorter bolt unit? Do I need a spring compressor with a one inch drop spring? I do not want a big drop. My arms have gotten a workout today.
Vancouver Bob
Robert Bergstrom is offline   Reply With Quote
Old 09-07-2010, 12:36 AM   #2
westofb
I really hate wet sanding!
westofb's Avatar
Re: Spring compression
If you are only wanting to install new spindles, there is no need to remove the springs from the truck. Put the truck on jack stands (on frame of truck), remove cotter pins from both ball joints, loosen both ball joint nuts about 3 or 4 turns (make sure you don't loosen them too much, leave some threads exposed outside the nuts, get a BFH, smack the crap out of the old spindle near the area of the lower ball joint to pop the ball joints loose, put a floor jack under the lower a arm to take pressure off spindle, remove ball joint nuts, lift up on upper arm to free spindle, install new spindle and your done.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 09-07-2010, 01:15 AM   #3
El Jay
Gone to greener pastures
The only thing that I would do differently is put the floor jack loosely under the control arm, before using the BFH.
Just in case there is some kind of freak, catastrophic failure with 1 of the ball joints.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 09-07-2010, 01:38 AM   #4
westofb
westofb's Avatar
Yes this is a good idea, I normally would do this myself, just neglected to add that step in my post. If one of the bj's failed without the jack in "stand by" position under the lower control arm, I wouldn't want to be standing anywhere close to it when that spring shot out of there!
Jeff,
68 C-10
10 F-150
Old 09-07-2010, 01:24 AM   #5
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Mine is a 3/4 ton so the springs are longer and stronger and I followed the suggestions above and it worked great. No need for a compressor.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 09-07-2010, 01:57 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
To add even more safety run a chain thru the spring and bolt the ends together.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-07-2010, 07:41 PM   #7
Robert Bergstrom
Sorry, I have a powdercoated frame I am working with. No engine or other weight on it. I wonder how the factory workers did it? I will look at rental places tomorrow to see if they have any compressors with a shorter center bolt.
Vancouver Bob
Old 08-04-2012, 05:53 PM   #8
Robert Bergstrom
Still have not installed the front springs. Did get 1 inch drop springs and plan on using the engine and transmission weight to compress them. Will that work? Just don't like the spring compressors I see at the auto parts store. How did the factory do it?
Vancouver Bob
