09-08-2010, 08:42 PM | #1 |
Junior Member
Driveshaft?
I am swapping the Dana 6 lug in my 69 1/2 ton with a 71 12 bolt 5 lug.Will I have to lenghten or shorten the driveshaft?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
09-09-2010, 02:25 PM | #2 |
its all about the +6 inches
Re: Driveshaft?
you may have length issues, and you may have U joint size issues too. I would try to get the rear shaft out of a 12 bolt equipped truck
09-09-2010, 05:31 PM | #3 | |
Junior Member
Re: Driveshaft?
I had my 72 3/4ton towed to the shop for its rear end troubles today in hopes it could be repaired vs swapped. The shopped called and said I need a replacement rear end that the one in the truck is beyond rebulding. I know the pin that holds the spider gears in sheared off but could that trash the whole rear en?.
09-10-2010, 08:17 AM | #4 |
Junior Member
Re: Driveshaft?
Anbody done this mod?
09-13-2010, 06:58 PM | #5 |
Junior Member
Re: Driveshaft?
The 5 lug rear end is almost buttoned up. The driveshaft lined up just needed a different ujoint.
