09-09-2010, 01:24 AM | #1 |
Another question about 73-87 crossmember
I have a 67 c10 and plan on using a 76 front crossmember that I already have. My question is will lowering springs for 67-72 trucks work with it or do i need springs specifically for the 76? I ask because you can buy kits with front and rear springs shocks etc.
09-09-2010, 05:18 PM | #2 | |
Re: Another question about 73-87 crossmember
09-09-2010, 07:19 PM | #3 |
Guessing for the disc brake set up? I know I am using a 83 front end for the disc brakes on my 67 so having to swap complete cross member over.
09-10-2010, 12:07 AM | #4 |
Just to make sure you guys are aware, there is no need to swap the x-member unless you want to. All the disc swap parts will work on the existing x-member.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-10-2010 at 12:07 AM. |
09-10-2010, 12:38 AM | #5 |
Am gonna swap for the disc brakes. And thanks for the replies, just wanted to make sure I order the right parts.
09-10-2010, 12:51 AM | #6 |
So if I just swap all the parts to my 67 crossmember I would use drop spindles I assume for the 73-87 and could use the springs for the 67-72 trucks? Im wanting to do a 3 and 5 inch drop.
09-10-2010, 06:06 AM | #7 |
you can swap all 83 brake parts to a 67 without changing crossmember?
09-10-2010, 09:00 AM | #8 |
TNT-MOTORSPORTS
I believe all you have to do is drill out the lower control arm mounting holes, the u-bolts that hold the cross shafts are bigger on the newer control arms.....I think ??? That being said I still put the entire crossmember under mine..... just because....!!!!
09-10-2010, 09:18 AM | #9 | |
Drilling the holes out is only required if desired. A guy can swap the disc brake parts to his original a-arms w/no issues. Coreyslude, if there's confusion about what is needed, check out the suspension section. There's multiple threads w/all the info needed for a swap to discs.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-10-2010 at 09:41 AM. |
