Old 09-09-2010, 11:53 PM   #1
GMC Guy
GMC Guy's Avatar
tach cluster
just picked up a tach cluster at the pick n pull. need to know what modifications need to be made to my wiring harness. i think i can go back and grab the main gauge harness out of the same truck. i'm converting from my stock 79 gauges to this 73-75 style tach cluster, but i plan on using my electric oil pressure gauge, and voltmeter. i know the wiring will be mismatched, so how do i make it work? thanks
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 09-09-2010, 11:59 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: tach cluster
send me the cluster and forget the headaches (: haha i know you have to run a wire to the distributor to get a tach reading
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-10-2010, 12:42 AM   #3
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Re: tach cluster
I just did mine but it has the gas gauge built into the tach, but for the ammeter to voltmeter change, one contact has to be moved from the 3 o'clock to the 12o'clock position for your old voltmeter to work with the new circuit board. Once you have the old one out, place them side by side and you see what needs to be moved. You'll also have to remove some of the clear insulation over the copper trace.
No need to swap harnesses. You can remove each wire with a small screwdriver and put it in the correct location for the new cluster. You do need the tach harness tho.
For the oil gauge, the mech gauge physically mounts differently to the housing then the elec one so you might have to make some kind of bracket up.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 09-10-2010, 12:50 AM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: tach cluster
Wiring for an amp meter gauge has a built in shunt somewheres in the system. Where I have no idea, You can't simply switch the cauges and call it good unless of course you wanna let the smoke outta all your wiring.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 09-10-2010, 12:53 AM   #5
DBLSPRT68
DBLSPRT68's Avatar
Re: tach cluster
I linked some info on you other post.
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 09-10-2010, 08:42 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: tach cluster
Some one want to put together a nice "How to" with pics. This would be an awesome FAQ...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-12-2010, 06:35 PM   #7
Justins76
Justins76's Avatar
Re: tach cluster
I'll see what I can do.
My cardomain page
