Old 09-10-2010, 08:56 AM   #1
DetroitIron
DetroitIron's Avatar
Wheel Bearing question...
I have a wobble/vibration in the drivers side front wheel of my recently purchased 84 K20. I was thinking it was the tie rod, ball joint, steering stab. etc.....Jacked it up and pulled the tire to see that the play/movement is actually in the hub area itself (manual hubs). I think it might be the bearing is shot, but it doesn't grind or make a noise....just that wobble feeling in the wheel. Other thing is that when applying the brakes the vibration goes away completely. Does this sound like the cause of my vibration? btw- the inside spanner nut is turned all the way in to where the threads stop on the axle so it's not that the spanner nut is just loose...also I purchased it with the front caliper frooze and trailered it home ( I had to replace rotor, pads, and caliper) so I'm thinking the bearing could have taken some heat/abuse leading up to it freezing up...what do you guys think? Thanks a lot!!!
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 09-10-2010, 04:57 PM   #2
LONGHAIR
Re: Wheel Bearing question...
You definately need to get that apart. Something is sreiously worn/damaged.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-10-2010, 05:18 PM   #3
irishman999
irishman999's Avatar
Just throwing this out there... maybe the spanner nut was to tight and it wore the hell out of your bearings causing everything to loosen.
irishman999 is offline   Reply With Quote
