Old 09-10-2010, 11:13 AM   #1
creep
Registered Loser
creep's Avatar
Water Temp Sender
I had to switch from a 305 V6 to a small block in my 63 GMC and need a new water temp sender for it. I know I need one for a gauge but do I need to find an exact replacemt or can I use another sender from a different year? Will the sender from the V6 work in the V8? I would think so but I thought I should ask first.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 09-10-2010, 11:17 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Water Temp Sender
There is no reason it wont work. You will just have to find a threaded location and you may need to adapt up or down depending on the pipe thread size. The adaptors are available at any hardware store.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-10-2010, 08:41 PM   #3
TR65
TR65's Avatar
Creep,
GM has used two different temperature senders. The ones for our trucks (usually 1/2" pipe threads) have lower resistance than the later model senders (usually 3/8" pipe or metric).
I have tried mightly to get the late model sender to work with our gages but I have not succeeded yet, and it is beginning to get out of hand. That is the last original gage I have not gotten to work with my LS2 swap.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 09-11-2010, 11:31 AM   #4
creep
Registered Loser
creep's Avatar
Thanks guys.
