Old 09-12-2010, 03:11 PM   #1
1968CHEVYC10
1968CHEVYC10's Avatar
88-98 anti-sway bar in a 68
I pulled the sway bar off my 97 burban, I held it up to my 68 just too see if it was possible. It looked like it might be possible with a little fabbing maybe. Anyway I was just wondering if anybody else had done it and how they mounted it. Thanks!
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 09-12-2010, 04:35 PM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Re: 88-98 anti-sway bar in a 68
don't know about that, but the 73- 87 sway bars fit with no mods i just did one myself off a 80something 3/4 ton just a thought
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 09-12-2010, 06:02 PM   #3
capev86
listen to Hubscrub, you must.....
the 73-87 2wd bar is an inexpensive, bolt in job for the 67-72 2wd's. the standard 1-1/8" diameter bar is identical to the bar that was optional on our trucks. you can find a 3/4 ton camper special or a 1 ton truck donor and it will give you the 1-1/4" bar that will be a totally stealth installation. don't forget the brackets that hold up the front of the bar. i'd only bother adapting a newer factory bar if it was from a late model.....1-1/2" front / 1-1/4" rear.
capev86 is offline   Reply With Quote
Old 09-12-2010, 06:04 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I agree.Got mine for about $18.00 at Pull-a-Part.They have an online inventory and pricing guide for each area.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-12-2010, 06:44 PM   #5
Blackjeep99
Ya I got one off an 87 3\4 ton with all the brackets for $35.00
Blackjeep99 is offline   Reply With Quote
Old 09-12-2010, 06:59 PM   #6
guyryan100
guyryan100's Avatar
Those of you who've done this upgrade, was it a noticible improvement? Is it worth the hours of hunting buying and installing the parts?
guyryan100 is offline   Reply With Quote
Old 09-12-2010, 09:30 PM   #7
Hubscrub
Cruzin
Hubscrub's Avatar
i can tell a difference in mine you don't have that leaning feeling anymore lol, i would honestly say that my truck with the stock rebuilt front end and swaybar drives as well as my 97 does and but probaly rides better than the 97
Proverbs 3:5,6
Old 09-12-2010, 11:49 PM   #8
ERASER5
ERASER5's Avatar
You betcha it is! Night and day difference. Worst case, 2 hour install if you have to cut the rivet with a hammer and chisel. Less time if you have power tools to remove the rivet.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-13-2010, 12:04 AM   #9
1968CHEVYC10
Thanks yall, I knew the 73-87 were pretty much a bolt in, but I figured since I had the one off my '97 I might as well try it. Anyway I didn't know the 73-87 were so cheap though, never really looked into it, but that's def an upgrade that's happening soon.
Old 09-13-2010, 12:11 AM   #10
BHyatt
I pulled a rear sway bar from an early 90's Suburban and plan to install it soon. It seems the options for the rear are all a bit more pricey than the $12.99 I paid for this one with all of the brackets and bolts. This is one of the few trucks that nearly every one I look under seems to have a rear sway bar.
BHyatt is offline   Reply With Quote
Old 09-13-2010, 12:14 AM   #11
1968CHEVYC10
was it newer than 91? the burban body style didn't change from the square body until 92, if it was newer that would be pretty cool since I already have one, how did it improve handling?
Old 09-13-2010, 12:31 AM   #12
BHyatt
It was the newer body style. I believe it was a '94. I have not installed the bar yet so we will see what the improvement will be.
Old 09-13-2010, 12:42 AM   #13
1968CHEVYC10
Cool guess I need to take that one off too and try it on the truck
