Old 09-13-2010, 08:43 AM   #1
CVA59
Serpentine Belt System Question??
I have a 64 model 283 (no bolt holes in heads) and i want to install a serpentine belt system. Will it work on my engine? Do there need to be bolt holes in the heads or does this system bolt into the block only?
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 09-13-2010, 10:40 AM   #2
andyh1956
Re: Serpentine Belt System Question??
i have installed several gm oem serp set-ups on engines. i used the 4.3 serp units, mostly cause that's what i could get for cheap. however in your case you are right to notice that the lack of holes is going to be a problem. also you prolly have a short water pump now, and the 4.3 serp set-up is gonna use a long pump. also the dampner diameter will grow so you will need to have a front cover or at least a timing pointer that matches the dampner you are using. there are also some braces that travel rearward to the intake manifold to threaded bosses your intake will not have. i don't know anything about aftermarket set-up so some one else will have to help there. having said all this you could change heads & make it work, but be carefull which heads you pick. don't drop a pair of heads on that 283 with 76cc chambers on it, you will kill that peppy 'lil 283, they use SMALL chamber heads. good luck!
andy
andyh1956 is offline   Reply With Quote
Old 09-13-2010, 11:06 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I put on one for my '68 project and it requires holes that are used in the block and the heads. Most pre '86 heads don't have one of the holes, on the pass. side, needed so I drilled and tapped the missing one. I don't think I would want to do that for all the missing holes on the early heads.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-13-2010, 12:12 PM   #4
CVA59
I may just have to change the heads and stuff like andy was saying. hmmm, i may have to think about this a little more.
Zack
www.23t.weebly.com
Old 09-13-2010, 12:37 PM   #5
Oklahoma
you will also have to change the water pump because the serp set-up requires the pump to turn in the opsite direction.
Oklahoma is offline   Reply With Quote
