resident wrencher
350 to 700r4 sawp
hey yall i want to swap my 350 for a 700 r4 what do i need to have or modifyly to make this happen i have a 2wd lwb 1980 chevy and a 700r4 out of a 86 chevy swb with a 4.3 whats the magic i need
Salty Sailor
Re: 350 to 700r4 sawp
if the transmission your replacing was a long tailshaft then its basically bolt in but if it is a short shaft youll need to shorten the driveshaft.
86 c-10 Custom Deluxe Savannah, Georgia |
resident wrencher
cool thanks man one more question what is the measurment on the long shaft v. the short
Insert Witty Text Here
Maybe this will help:
![]() Slonaker |
If your truck is lowered and you have a long tailshaft 350 you will need to shorten your drive shaft. It was an unsuspected surprise when I put my 4" lowering on last fall.
I never wrote down how much i needed to shorten mine when I lowered the truck so you would have to measure.
Stu- 1981 GMC Sierra Classic LWB 355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992 700R4-2000 stall with lockup, shift kit, Corvette servo 3.07 open diff- I need a 3.73 posi! 2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me. |
resident wrencher
ya mine is bone stock i just need that extra gear to get me places in an effecint manner i drive mine every day
resident wrencher
so basicly the 700 is gunna be roughly 30 inches long and to make a direct swap i need the 350 with a 9 inch tail to make the shaft fit
False Lies
Look into the T.V. Cable hook-up (commonly mistaken for a kick-down cable). Geometry of the bracket is extremely important for proper shift-points, transmission behaviour and reliability.
you can make your own bracket, or order one to adapt your existing trottle bracket to the proper geometry for the 700r4. If you dont do this, you will burn up your tranny. There's adaptor brackets available for all sorts of carbs/throttle bodies that usually run around $60, and are super easy to install. Even possibly taking the throttle bracket off the 4.3L and getting it to fit your engine's carb would work. Also be sure to take the cable mounting bracket (however, it should fit/clip in the same place a T350 kickdown cable does anyway) Go here for some good info: http://www.tvmadeez.com/article/index.php http://purplesagetradingpost.com/sum...o/700R4p1.html Once everything is in place, its simple to set up! You just adjust it so the T.V. cable is fully pulled out/extended at WOT (Wide open throttle). As well, find out if its a locking torque converter or not... if it is, its simple to wire in (its an electric solenoid) and the schematic can be found lots of places. You could also rob that off the donor truck (if equipped). Done deal.
Kyle (Steemin) Ehman -1979 Chevy CCLB, 6.7L Cummins swap - Project "RAMERADO" -2015 Yukon XL Denali (Family ride) -1977 Chevy stepside, carb'ed vortec 350 (SOLD) -Father of three daughters who will also have something cool... Last edited by steemin_ehman; 09-15-2010 at 08:27 PM. |
From what I have been told , a v6 700r4 is not the same as a v8 700r4 there are differences but I am unsure exactly what it is but it might be wise to do a little research beforehand.
Salty Sailor
the main difference is how much horsepower it can handle
False Lies
I have a buddy that did a 350 swap (mild) in an s-10 that originally had a 4.3 v6. He had no issues at all with his factory 700r4 tranny after setting it up properly. For this specific install, there shouldn't be any issues with fitment or having too much power for the 700r4.
Kyle (Steemin) Ehman -1979 Chevy CCLB, 6.7L Cummins swap - Project "RAMERADO" -2015 Yukon XL Denali (Family ride) -1977 Chevy stepside, carb'ed vortec 350 (SOLD) -Father of three daughters who will also have something cool... |
resident wrencher
ok so the tourqe convertors are gunna fit the same
False Lies
Yes, the bolt pattern on the 700r4 torque converter is the same as a T350. The only difference is that the bolts sometimes need to be metric... I'm not 100% sure if all years of 700r4 are metric or not.
resident wrencher
ok sweet guys thanks for all your help
#15 |
resident wrencher
so how can i set up the tv cable in a good manner
#16 |
BAD BOW-Silverado XST
Which carb are you using?
TV cable adjustment: http://www.73-87.com/7387garage/drivetrain/tvcable.htm |
#17 |
resident wrencher
rochester q jet
