Old 09-15-2010, 01:51 AM   #1
dave69
belt routing w/o A/C 96LT4 swap
Any way of routing a smaller belt w/o A/C on a 96 LT4 swap? I want to run everything else on the engine, alt. P/S, tenioner and idler. I could run the a/c pump just for a pulley but don't want something that is not working. I don't need a/c. must be a way to do this with out buying differant brackets.
dave69 is offline   Reply With Quote
Old 09-15-2010, 11:02 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: belt routing w/o A/C 96LT4 swap
Is this the GM serpentine belt setup? If so, they sell a A/C delete pulley. It basically replaces the A/C compressor with a standard pulley that is the same size. You still use the same belt and routing.
I bought mine from Rock Auto online. About $40 or so, depending on application.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-15-2010, 01:06 PM   #3
dave69
Yes in is Gm serpentine belt set up thanks I will check on Rock Auto.
Old 09-15-2010, 03:42 PM   #4
dave69
I like that idea does it come with a bracket and pulley that bolts to the A/C bracket? Can you send a picture of it. I looked on there sight but didn't see anything other than pulleies etc.
Old 09-15-2010, 01:09 PM   #5
6772owner
Gearhead
6772owner's Avatar
Thats what I did on my LT1, I had to trim the framerail to allow clearence for the delete pulley though. The pulley sits right in the curved "lip" thats bent up on the frame, I purchased the pulley on E-Bay for a good price, you might check there as well.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 09-17-2010, 02:21 AM   #6
dave69
Thanks for your imput I will get a delete pulley, I seen on an other post the you did your wire harness your self I am starting on mine so if you any advice or where to look on line that would helpful thanks let me know. Dave
Old 09-15-2010, 04:45 PM   #7
6772owner
Gearhead
6772owner's Avatar
Yes mine was a bracket and pulley, you can get all the info and pics in my build thread.
