Old 09-19-2010, 04:22 PM   #1
theCure
theCure's Avatar
How to remove key switch?
Just picked up a 72 C10 swb for $100 but PO lost keys. Any ideas on removing it from the ignition switch or should I just go buy another ignition switch? Already bought a new key switch so would prefer to use it.
1972 Chevy C/10 SWB Project.....
1969 Chevy C/10 SWB Step-Side Sold
1996 Chevy Camaro SS Sold
1989 Thunderbird SuperCoupe 5-Speed MINT! Sold
1988 Thunderbird TurboCoupe 5-Speed Sold
1991 Camaro Z28 Convertible Sold
theCure is offline   Reply With Quote
Old 09-19-2010, 04:43 PM   #2
Wrenchbender Ret
Re: How to remove key switch?
you can't hardly remove the tumbler without the key without tearing the whole thing up. I believe the doors use the same key. You can pull the lock out of the door very easily. It has numbers on it that a key shop can make a new key from. Pull the door & window handles & the door panel. Pull out the clip & remove the lock.
Wrenchbender Ret is offline   Reply With Quote
Old 09-19-2010, 06:40 PM   #3
DPowers
One foot in front of the other
DPowers's Avatar
Also if there is an older hardware or locksmith in your area- alot of times they will be able to help.
DPowers is offline   Reply With Quote
Old 09-19-2010, 08:40 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Turn the key to the left as far as it will go and insert a straightened paper clip or stiff wire into the hole in the face of the cylinder and “gently” push the spring loaded pin in. Turn the cylinder further to the left to remove it.
After you push the spring loaded pin in with the stiff wire and turn the cylinder further to the left you have to pull the wire out to finish turning it or it will bind. You can also turn it too far after you pull the wire out. That is when you have to wiggle the cylinder back and forth a little bit. If you wiggle it too much the pin will pop back out and you will have to start over. You should not have to put excessive turning pressure on it or push down hard on the spring loaded pin. Gentle and patience are the key words here...
For the people that read this thread that do not have an ignition key take the passenger door lock out and take it to your local locksmith. It should have a code number stamped into the lock case and the locksmith can cut a key from the code number. If none of the locks have been changed the key will fit the ignition.
The attached image shows the code location.
LockDoc
Leon
Old 09-20-2010, 09:18 AM   #5
theCure
theCure's Avatar
awesome.... thanks!!!
