Old 09-20-2010, 08:23 PM   #1
brans72
83 brake booster?
anyone got a picture of a 80's (using a 83) brake booster installed in 67 C10? I am curious to see how you mounted and put the pro. valve at in your truck. Thanks Brandon
brans72 is offline   Reply With Quote
Old 09-21-2010, 07:39 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 83 brake booster?
I think the booster will bolt on with just a few holes drilled into the stock bracket.
I did this swap about 15 years ago on a 69 suburban I had.
I used the stock "distribution block" bracket to hang the 73-87 prop valve under the master cylinder.
The 73-87 prop valves have two front brake line ports. (instead of one, on the 67-72 version) But you can always plug that extra port.
If it were me,... I like using an aftermarket Prop. valve and M/C.
I like this combo unit from POL (www.PerformanceOnLine.com)
Both the M/C and Prop. valve are aluminum and don't require paint or won't rust later on.
They will stay looking good for a long time!
Keith
Convert to disc brakes.
