Old 09-21-2010, 11:48 AM   #1
storked82
storked82's Avatar
Speed QUESTION
Hello Guys
looking to purchase an after market speedometeor for my truck, I'm wanting something that will be accurate. Tire size is P275 50/15 all the way around. The rear end gears are 273 stock. The motor is a 383 stroker. I'm really wanting something that will be accurate. Any help and suggestions are welcome. Thanks and if any of you have pictures or other websites that would help I would appreciate that also.
Thanks,
Jeff Main
storked82 is offline   Reply With Quote
Old 09-21-2010, 03:32 PM   #2
kris's66lwb
resident wrencher
Re: Speed QUESTION
the stock ones are accurate enough its all about the speedo gear in the tranny it has to be the correct one for you tire size and rear gears and properly fit the tranny and no chips or worn teeth or itll bounce around a lot or if you have a newer truck a claibratble vss will do with a elcetric speedo
kris's66lwb is offline   Reply With Quote
Old 09-21-2010, 03:53 PM   #3
Clyde65
Clyde65's Avatar
Re: Speed QUESTION
GPS speedo, you dont have to calibrate nothin, just hook up power, ground, antenna and lights, you off!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
