turn on headlights and gas gauge goes to zero
just did a motor swap and now when i turn my headlights on my gas gauge goes to zero and my dashlights are non-existant and my buzzer goes off.....anyone have a clue as to what i did or didnt do????
Ross K 1985 Silverado LT1 1970 Chevelle SS396 |
Re: turn on headlights and gas gauge goes to zero
is it just your gas gauge that stops working?
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
![]() Join Date: Dec 2008
Sounds like a loose wire somewhere. Ground or something. Either that, or you're getting bad bad BAD gas mileage. Lol (Christine, relatives maybe?)
I would second the ground issue as you have a high resistance somewhere. You can still have good voltage but as son as you have current that voltage will drop quick with a high resistance connection such as a bad ground from the chassis to the cab.
![]() Join Date: Sep 2010
Bingo, this is clearly the issue.
yes its only the gas gauge.....ill go over the grounds as that seems to make sense thanks guys!
#7 | |
humm what happen to dashlights are non-existant and buzzer goes off |
im looking at schematics right now....it seems that i must have something crossed as well .....i installed a new headunit and i hooked everything up prpoerly so i think....guess ill pull that out and take another look
