View Poll Results: What kind of paint scheme | |||
Orange on bottom fade up to black with black tinted windows |
2 | 22.22% |
All Blacked Out Oil Slick |
1 | 11.11% |
Solid Orange |
2 | 22.22% |
Flat Orange Low Gloss (matte/Egg shell-ish) Just not shiny |
1 | 11.11% |
All Blacked Out Low Gloss (matte/Egg shell-ish) |
3 | 33.33% |
Multiple Choice Poll. Voters: 9. You may not vote on this poll |
70Custom10
70 Shortbox Chevy 2wd considering a GM 3800?
Hi there this is my first thread. been coming to the site for years though. As the title says I have a
![]() ![]() PS any mod suggestions or your favorite mods for this Gen body style are welcome to. ![]() Last edited by blazerboy_4life; 09-26-2010 at 11:50 PM. Reason: Changed Photo to smaller pic |
No No
Re: 70 Shortbox Chevy 2wd considering a GM 3800?
wow need to reduce that picture down a tad.
For starters van engine is a FWD going to need special mounts to get it to fit different mounting points then the RWD f body engine which are closer to what you would want. Need to use a trans from a small 6 as well v8 tranny wont bolt up. FWD engine has the manifold pointed the wrong way no big deal it fits either direction but the SC intake can only go one way and work. Since you got some room to work with the truck engine compartment and you need to fab custom mounts anyway I could see it being able to be run with the throttle body pointing toward the firewall just would require custom duct work. I know pople that have left the stock non sc ecm and ran a sc on there 3.8l fwd's i recommend getting an ecm made for a sc engine as well as the correct knock sensor.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
![]() Join Date: Jul 2010
it will need more tha jus tha s/c to make that motor run...goggle Top swap & you see what i mean. that lil 3.8 will catch h&^l tryin to pull that truck around
A member on the Chevytalk board installed a Buick turbo engine in his truck and was extremely happy with the performance. His install was a little easier than yours because he started with a RWD engine from a G-body, but I don't think you will have any problems you can't overcome. You will have a huge amount of room to work around the engine.
For a transmission, I am thinking maybe 4th gen Camaro/Firebird. S-10 4 cylinder and 2.8 V-6 transmissions will also bolt up, but the F-body came stock with a 3800. Ray |
#5 | |
70Custom10
70Custom10
Forgive me if this is a stupid question but what body styles do the term F-body apply to? I know it would be better to put a rear wheel drive motor in but the only difference is the intake correct?
ok as above your idea is good but you need a little help..
the van is fwd. get a f body (camaro/ trans am) 3.8(3800) and the tranny. I'd if you don't want the wire'n nitemare get the 3.8 buick(same engine) out of a g body or b body (get the buick it has the dissy in the front, the chevy is dissy in the back and is a 229 the buick is 231) get the mounts frame stands all of it.. the engines will have a 2brl carb , unless you get a t type or g/n 3.8 it bolts into the truck use'n the sbc frame stands to mount the motor mounts to. (you'll have to drill a few holes in the frame stand(trucks) other than oil leaks they run forever.. if you wand efi and spark control. the latest f body you can find, some had sticks.. but remember the tranny is at an angle to fit under the floor of a f body.. and may cause fits when installing under the truck.. good luck.. FYI IF YOU CAN FIND A 3.8 Q JET INTAKE the older 3.8 will get the same mpg as the efi one. within 1mpg. untill you hammer it.. then all bets are off.. a 2nd gen f body inline 6 will get you better mpg. as it makes more ft lb down low.. but the 3.8 will run away from it when you slam the hammer down |
No, it's not a chevy truck they are talking about, but I would go to www.bruntonauto.com. Look at the installs of the 3800 with supercharger. They offer a plug and play wiring harnes to mate the 3800 Park Avenue with blower to a manual transmission. I keep thinking about it for one of my trucks but my kids keep taking all my money. Always wanting something.........food, clothes, shelter, it just never ends.
Tags |
3.8, 3800, 700r4, motor, motor swap |
