09-23-2010, 11:41 PM | #1 |
Adjustable track bar??
Getting ready to lower a 71 longbed 4 inches and I am installing a adjustable track bar. It doesn't have directions so how do I adjust it?
09-24-2010, 04:49 AM | #2 |
Re: Adjustable track bar??
The ones I am familiar with have a threaded sleeve you can turn, like on a tie rod. If yours isn't like that, please post a pic of it.
Ray |
09-24-2010, 07:31 AM | #3 |
it is like that, just curious how to get the correct adjustment.
09-24-2010, 07:35 AM | #4 |
use ruler and maesure to have equidistant tires
09-24-2010, 08:04 AM | #5 |
Under Construction
The object of the track bar is to center the rear end in the frame. As Cdowns mentioned, use a tape measure and get the rear centered. We measure from the back of the tires to the frame to get ours centered..
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
09-24-2010, 10:15 AM | #6 |
^^ Yep, that sums it up. Center the rear as much as possible @ ride height. Adjust the bar accordingly & install it. Re-measure, then adjust left or right as necessary by disconnecting the adjustable end of the bar & threading it in or out.
I use a ratchet strap on the frame & suitable location on the rear housing to tug it one way or the other if needed.
09-24-2010, 10:19 AM | #7 |
Recheck after a week or so of driving.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-24-2010, 07:04 PM | #8 |
Thanks guys!
