09-25-2010, 10:26 PM | #1 |
Still plays with trucks
78 delay wiper conversion questions
What needs to be done to install a delay wiper switch & delay module into a truck that did not come with them stock?
I scored a delay switch and module with pigtail at the wrecking yard today and I badly need delay wipers in my 78 K20. I assume I will need to cut and splice some wires off the back of my standard switch to make the connections to the delay module connector. I really doubt I can repin the connector but I will give it a try and see it the two different connectors share pin types. Not likely but it is worth a shot just in case. Anybody do a how to or have insight to give on this? Wiring diagram? I can't afford to screw up my wipers now that fall is here. Same truck had part of a tach dash left so I got the small fuel gauge out of it too while I was at it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
09-25-2010, 11:31 PM | #2 |
Re: 78 delay wiper conversion questions
Should be plug and chug. 78 Chevyrado over on the 73-87 board did it to his and he said it was a simple remove/replace operation. I tried to find his thread on it, but couldn't. You might shoot him a PM and see what he says.
09-26-2010, 12:10 AM | #3 |
plug and play using a delay switch and delay module
the non delay switch plug, plugs into the module and the module plugs into the delay switch. I have tried a few and had no luck getting a good pair (module and switch) when i had my '80 even when they work, they can be very finicky and come on whenever they want I've had better luck with the newer style with the wipers on the turn stalk you could build your own circuit intermittent-wiper-controller
CHEVY ONLY Last edited by joe231; 09-26-2010 at 12:16 AM. |
09-26-2010, 09:51 AM | #4 | |
I will put it in today and test them out. I considered installing a newer column with the turn signal stalk control but haven't seen a manual trans column with them yet. I do have a couple of the delay modules from the newer columns. Any idea if the newer module can be installed in place of the older one? It might address the finickyness of the older setup.
09-26-2010, 10:37 AM | #5 | |
Oh and I believe the columns are the same up to '94 in the newer body style
CHEVY ONLY Last edited by joe231; 09-26-2010 at 10:38 AM. |
09-26-2010, 11:03 AM | #6 | |
I will give the older one a try and see how it works and go from there. I would love to see those wire diagrams if you can track them down.
09-26-2010, 11:48 AM | #7 |
Just compared the newer delay module to the older one. Output wires are the same count and colors so that is no big deal there.
Input wires are different colors and the number of wires is different. It will take a little research to make that side work right without messing up a delay module or two.
