Old 09-26-2010, 01:06 PM   #1
big d's red67
big d's red67's Avatar
need help with my 454
I am putting my 454 together and i have run into a problem, when I bring number one piston to tdc my timing mark on the balancer is pointing at the 5 o'clock position. has the outer ring on my balancer moved, do I have the wrong balancer ( is that possible), am I doing something wrong. Thanks for the help.
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 09-26-2010, 01:18 PM   #2
QKENUF4U
QKENUF4U's Avatar
Re: need help with my 454
could be either of those ...... old balancers will slip if the rubber ring between the halves is wore out...
QKENUF4U is offline   Reply With Quote
Old 09-26-2010, 01:27 PM   #3
tonypaul
tonypaul's Avatar
did you change your timing pointer maybe to a chrome or aftermarket one?- just reread your post.... I think you got the wrong balancer...
tonypaul is offline   Reply With Quote
Old 09-26-2010, 07:45 PM   #4
big d's red67
So there is more than one type of balancer for the 454?
Old 09-26-2010, 10:15 PM   #5
tonypaul
tonypaul's Avatar
Shouldnt be... did you get it in a kit? Can you post a pic?
Old 09-27-2010, 10:42 AM   #6
turp mcspray
turp mcspray's Avatar
If the balancer is used, then I would say the outer ring has walked. I have run into this more than once myself.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
