09-27-2010, 11:58 PM | #1 |
Chassis set up and correct engine position?
I'm trying to finish up my IFS install so I can move to the back of the truck. Question is how many degrees down is ideal for engine placement? It's mocked up at 5* right now but I'm thinking 3* is were it's supposed to be? Can somebody refresh my memory so I can weld these in. Thanks, TJ
1958 Fleetside shortbox 1965 Malibu SS 1970 Camaro RS 1972 Malibu wagon |
09-28-2010, 07:54 AM | #2 |
Hollister Road Co.
Re: Chassis set up and correct engine position?
Get a manifold on the motor and set the carb base to level.
09-28-2010, 02:11 PM | #3 |
^^^ Is that the way to do it on an LS series engine??? Remove the intake and set the level on the galley cover and set engine to level or set it at 3 degrees down???
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To |
