09-28-2010, 05:44 AM | #1 |
WTB sway bar chassis brackets
I went to the local U-Pull It and took a sway bar off a 71 C20.
Will those frame brackets mount on to my C10? Who sells these? |
09-28-2010, 06:37 AM | #2 |
"THE GREEN GOBLIN"
Re: WTB sway bar chassis brackets
Are you talking about these?and these.. earlyclassic sells them I have seen them for stock hight trucks and some for lowerd trucks
http://www.earlyclassic.com/catalog....hock+absorbers
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
09-28-2010, 06:43 AM | #3 |
"THE GREEN GOBLIN"
Also (CPP) classicperform has them for stock hight and lowerd trucks as well..
http://www.classicperform.com/6092chevtrk.htm#11
Petey-pablo
09-28-2010, 07:30 AM | #4 |
The originals from the donor will work. But you'll probably like the brackets for lowered trucks better
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
09-28-2010, 11:47 AM | #5 |
Junior Member
cant you just bolt the bushings on without the brackets?
frontstreetcycle on Instagram |
09-28-2010, 12:15 PM | #6 |
Yes, on lowered trucks no problem. You can also use the stock height brackets and put the sway bar "inside" of it, gaining clearance.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
09-28-2010, 03:40 PM | #7 |
I couldnt bolt mine to the frame cause it hit the front cross support. I could trim it down some to clear, but I decided to make some spacers out of some -1" aluminum I hade laying around....
