230 to 250 swap (clutch linkage)
I searched this topic a couple different ways and almost found what I was looking for but not really. The threads I found had dead ends to my questions.
My 230 has spun a rod bearing so I bought a 78 doner truck with a 250/350TH. I'm going to keep the truck a manual but am swapping the 4 spd out with a T5. The thread I found says that the swap is pretty straight forward but the clutch linkage is different but was not explained how it was different. Does anybody have any info on the different linkage if it is different? Looking at the block on the 250 there are the same holes for mounting. Are there any other issues I may run into? I plan on running a header and the old intake. Thanks for any advise. |
Re: 230 to 250 swap (clutch linkage)
I returned your pm.
![]() Join Date: Apr 2001
the T5 may need a hydraulic clutch set up depending on what the bell housing dictates... they are available aftermarket, but did come stock on manual gm light duty trucks after 1985 I believe....
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
I'm not worried about anything inside the bell housing. I will be using my stock flywheel, pressure plate and TO bearing with an S10 disc. I read another thread about a 230 to 250 swap. They were thinking of doing a swap and keeping the 3 on the tree and somebody replied saying the linkage was different. It looks like the bell crank mount is in the same place on the 250 so I was wondering what they were talking about being different.
Where can I buy a new 6 cyl bell crank. I have found a bunch for V8s but no 6 cyl. Mine looks very worn, might as well tighten everything up while I'm in there. I've got other parts ordered and would like to have most everything here that I need. |
No change in the clutch linkage is necessary. Keep your stock clutch linkage and everything inside the bellhousing except for the clutch disc. You will need a 14 spline disc from either an Astrovan or S-10.
The only modification needed (besides the driveshaft and shifter hole) is to shorten the input shaft pilot and bearing retainer on the T-5. If you want to pay for this adapter plate, you won't even have to modify the transmission. http://hamiltonintakes.com/products/s10t-5-adapter.html Ray |
After looking over both engines I didn't think there were any differences since there are holes for the mount in the same place. I got my 14 spline clutch disc today and have already ordered the spacer from Hamilton. This trans was supposed to be for my 55 but since I'm doing the engine swap the 65 gets it first.
I've done the exact same swap your doing..my truck was a 230/3 on the tree,,is now a 68 250 with a t5,,only thing changed is the clutch disc and shortened driveshaft...MY .02 the t5 swap is the best thing you can do to these trucks,,,,
I'm getting excited about the swap because I'll be able to drive it even more. I hope to get rolling on it this weekend if all my parts are in.
and a few others
Interesting. You didn't cut the pilot shaft? I didn't know it would work that way.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi Last edited by 63 & 64 Bowties; 09-29-2010 at 11:21 AM. |
