09-29-2010, 08:43 AM | #1 |
Another 1959 Apache build!
Hi yall, this is Cory out in the big D. This is my 1959 Chevy Apache, I am the second owner of the native Texas truck. After finally getting ahead at work I am able to finally get my project in the shop! She's going to be getting a 78 trans am subframe assy. this friday and I am starting work on the 4 link system, setting ride height etc. A lot of pictures to come but here she is before the teardown. Thanks for lookin!
09-29-2010, 09:04 AM | #2 |
Re: Another 1959 Apache build!
Here is the subframe I picked up. I saw the car completely assembled. The guy had the engine out and in the subframe in the bed of my truck in an hour. Crazy! The great thing about getting a later year is that I got the HUGE sway bar and heavy duty suspension with quick ratio steering box. Once I get going on it I will post more pics.
Here is is about 45 minutes into removal. That guy works quick! I mean the car was fully assembled! an hour later here it is ready for install! |
09-29-2010, 10:25 AM | #3 |
Sounds like a nice project. We do like the build pics so keep them coming. Kim |
09-29-2010, 11:44 PM | #4 |
Here's how we remove parts in Texas! It is a ford 8.8 out of an lincoln. It has a posi and disc brakes with 3.08 gears (bleh) but it is the equivalent to a GM 12 bolt. Should hold up well to the beating it will get. I am narrowing it to fit 10 inch wide chevy rallys. The truck will have the same front runnerish style rally's up front. (Though I do have some vintage 14" radirs but not sure if they will clear calipers)
Here it is at my shop about to cut off all the unneeded brackets. |
09-29-2010, 11:50 PM | #5 |
Out with the old and in with the new.
Just temporarily mocked up until I get it back to the shop to set do subframe and install 4-link etc. NO it will not sit this high! IM shootin for around 5 inchs of rocker height roughly. MORE Pics to come!! |
09-30-2010, 12:36 AM | #6 |
Cool I will have to follow your build. I am building a 55 myself and was just wondering what to do about the rear end. Are you tubbing the rear?
09-30-2010, 07:07 PM | #7 | |
While looking at it last night it would be easier to tub it because I want my tires close to the outer lip as possible and I am not crazy about how much the wide fenders are cost wise. SO most likely I will tub it. That way I can run a larger tire in the future and only change wheel offset. It could go a few different ways... |
10-01-2010, 12:10 AM | #8 | |
Kim |
10-01-2010, 01:01 AM | #9 |
Ya, I have never seen them but I measured out 3 inches from the original fender and it looks stupid. I am going to tub. Im going to look at tubs available to ease the process a little so I don't have to make something from scratch.
10-01-2010, 06:10 AM | #10 |
A320 Pilot/USAF Retired
Tub it!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
10-02-2010, 11:09 PM | #11 |
Well thats where I am at as of today. More pics to come!!
10-05-2010, 08:31 AM | #12 |
I wanted to note that the 58-59 inner fender aprons need to be trimmed a lot to clear the newly added control arms. Take your time and mark them out with a sharpie and come up on it to keep it clean. You will need a buddy to help you lift the clip and fit.
10-10-2010, 10:05 AM | #13 |
Got the clip done yesterday. My measurements changed a bit. I highly recommend for you to fit the front fenders and marl where you want the tire to sit in the fender and make your own measurements and set the subframe up to what looks best to you. I decided to not go 2 inches forward. It ended up being more like 1 3/4 but I will remeasure if somone wants to know. what do ya think? the engine is not in it at the moment.
here it is sitting @ desired ride height prior to subframe mock up. Here it is with my desired wheel location marked on fender and clip clamped in place. here is a top shot. The wheel is centered but looks off from this high! The 58-59 fenders are wider and aren't so close as the prior years I believe. Last edited by Wheelie; 10-10-2010 at 10:16 AM. |
11-23-2010, 07:28 PM | #14 |
So I have been busy cleaning up the ford 8.8 rear end and went ahead and put some 3.73 gears and all new bearings and seals.
11-23-2010, 07:29 PM | #15 |
Also cleaned up and assembled my corvette muncie 4 speed with hurst shifter.
11-23-2010, 07:34 PM | #16 |
I have also decided to wait on the 4 link and set-up with leafs for now to speed things along and save some green. So here she sits, I need to weld the spring perches on the 8.8, c notch the frame and possibly flip the mounts and lengthen shackles to get the ride height I need. Still a lotta work!
11-23-2010, 08:08 PM | #17 |
Nice progress man, keep up the good work!
11-23-2010, 08:41 PM | #18 |
That Vette transmission is junk and should not go in a truck. Send it to me for my 64 Chevelle and I will get you a real truck 4 speed, sm460 0r sm465, your choice!!! Does you customer know you took his tranny (cars in background)???
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 11-23-2010 at 08:42 PM. |
11-23-2010, 08:50 PM | #19 |
Junk? lol! Im prob going to put an auto in it if I do anything else. I like the gearing in the early trans. It has the rare 2.56 1st gear if I recall. Hell I have 2 or 3 of them. If you need one I can probably set you up. I think I have a truck one lying around but I don't like the granny gearing.
12-21-2010, 09:32 PM | #20 |
Can you show pictures of the tie in of the subframe. Did you run the arms under the frame and weld or did you chop it off and weld with plates over it?
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
12-21-2010, 11:01 PM | #21 |
Cool work man, Hey i like the vets in the back ground.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
12-21-2010, 11:20 PM | #22 |
HHHMMMM You cut your stock frame at different lengths pass. side is a little longer than drvs.side.I got lost on this did you eventually cut them the same?
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
12-22-2010, 08:58 PM | #23 |
Yes, I cut just behind the steering box on one side and just lopped off the other with the old eyeball. They are now equal and square.
Last edited by Wheelie; 12-26-2010 at 10:42 PM. Reason: didn't make sense before! |
12-22-2010, 08:56 PM | #24 | |
12-16-2011, 12:07 PM | #25 |
I have a 58' that i am eagerly awaiting to get tearing into, it is all original, but 75% of the fenders are trash. But it has the OE 235, with a 3 on the tree.. I am so glad to have found your thread, i have been wanting a visual on someone actually doing a sub frame swap on a 58-59.Thanks for the pics! keep em' coming!
