09-30-2010, 10:53 PM | #1 |
What's a good harmonic balancer puller/installer?
i will try the search function as well, but in the meantime what's a decent harmonic balancer puller/installer?
1) When i say decent, i mean one that will basically do the job; i will consider harbor freight type stuff----i won't be using it that often. 2) Also, i'm not sure if i will need a puller to take the timing chain sprocket gear off the crank, so we should take this into consideration also----should i get a puller that can do both? |
10-01-2010, 12:21 AM | #2 |
Re: What's a good harmonic balancer puller/installer?
KD Tools (KD 2286)
http://www.tooltopia.com/kd-tools-2286.aspx This what I use. Do NOT use a 2, 3,or 4 jaw puller. You will pull the balancer apart and destroy it.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
10-02-2010, 09:40 AM | #3 |
Tavia makes a tool for this and it is reasonably priced too if memory serves $26.00 check with Summit/ Jegs cheers, Pat
10-02-2010, 12:08 PM | #4 |
the one i've been using for 30years i bought from jcwhitney
10-02-2010, 12:29 PM | #5 |
I went to autozone and used theirs for free... go to the desk and look at the placemat with all of the tools for rent. You basically buy them and then return them when you are done, money is fully refunded...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
10-02-2010, 01:54 PM | #6 |
the gas money i've saved from trips back and forth to autozone for 30years has more than justified the expence// if i decide at 3AM to pull a balencer i just go to my toolbox a short 10foot trip
10-06-2010, 02:11 PM | #7 |
.. what CDowns said... i think thatz where mine came from ... still working well after all these years............. not sure if it will work on the LS engines.. will find out soon
