Old 10-01-2010, 08:12 PM   #1
cochino12
It followed me home?
cochino12's Avatar
Another coil cutting question, or heating to tweak?
So I cut a full coil off my dually and I think it still needs to come down another 1". Can I cut just a 1/2 coil off? If I do that it the bottom of the spring wont sit in the pocket right, is that ok? I know that heating coils for drop is a no no but is it bad if all I need is 1"
Or
Do I just pony up some $$ and buy some 3" drop coils? I realize thats probably the best option but like everyone else I want to get out of this as cheap as possible
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 10-01-2010, 08:17 PM   #2
mongoose
mongoose's Avatar
Re: Another coil cutting question, or heating to tweak?
take em out and cut em again..
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 10-01-2010, 08:28 PM   #3
cochino12
cochino12's Avatar
so it's ok that they wont line up with the pocket in the lca?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 10-01-2010, 09:16 PM   #4
mongoose
mongoose's Avatar
just rotate the spring so the last of the coil sit in the little channel
Old 10-01-2010, 09:28 PM   #5
cochino12
cochino12's Avatar
That doesnt work because the top of the spring pocket is ovaled
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 10-01-2010, 09:31 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Correct.
This is what I've tried to say on here before, in another thread.
Line up the top,... don't worry about the bottom.
Keith
Convert to disc brakes.
Old 10-01-2010, 08:35 PM   #7
lolife99
lolife99's Avatar
I say YES.
Others say no.
But I've done it at least a half dozen times.
Keith
Old 10-01-2010, 08:42 PM   #8
scooterskoolkustoms
scooterskoolkustoms's Avatar
I bought new lowered springs and the don't fir in the pocket.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 10-01-2010, 09:38 PM   #9
nbpro
I've read somewhere where certain types of front coil springs are unsafe to cut. But that was a place that was selling lowering parts. Lol. As far as I would go is the 2 inches you already have, and be safe. So the 3 inch drop coils would be the thing to do. No guessing that way. You'll know whatcha got.
nbpro is offline   Reply With Quote
Old 10-01-2010, 10:05 PM   #10
lolife99
lolife99's Avatar
1/2 coil= 1" drop,... as a rule,... but not a for sure. Ha.
If you think it will be too much,... cut 1/4 coil.
When it's all said and done,... the coil will be a "given" length.
And it will only compress so much.
The only way to screw up,... is to not get the top seated.
I ususally lay on my back and verify the spring is seated in the upper "D" shaped retainer.
I also mark the front of the spring with a marker or tape.
This will help verify the spring hasn't rotated while you are messing with the lower a-arm and balljoint.
Don't install the shock or the sway bar until you are happy with the ride height.
And,... we need pics!
Keith
Old 10-01-2010, 10:14 PM   #11
cochino12
cochino12's Avatar
Thanks for help Keith. I'll get some pics up Monday, I should have it sitting right by then. Just picked it up from paint AGAIN today and it looks soooo much better now
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 10-02-2010, 03:35 PM   #12
Malo83
Cruzzzn' Vet
Malo83's Avatar
1 complete cut coil is 2" in drop
Malo83 is offline   Reply With Quote
