Old 10-05-2010, 07:35 PM   #1
trkfrk
trkfrk's Avatar
Started my first frame off - 72 SWB LS1, 6-spd manual
I'm new to the site and love it. I purchased my truck from Ebay about 3 years ago - an actual AZ truck with only surface rust. started on the tear down in August. here are few pictures - wish me luck..
trkfrk is offline   Reply With Quote
Old 10-05-2010, 07:40 PM   #2
Ed 72 Sierra Grande
Ed 72 Sierra Grande's Avatar
Re: Started my first frame off - 72 SWB LS1, 6-spd manual
Sweet Truck and nice garage. Keep us posted on your build.
Have the same parts washer, What kind of solvent do you use these days?
Good Luck
Ed F
1972 Sierra Grande
White Top Medium Olive
402 bb / Camper
Stock, Loaded, Straight & Aged Nicely, No Tilt
Original Resto would be nice $
Ed 72 Sierra Grande is offline   Reply With Quote
Old 10-06-2010, 10:59 PM   #3
trkfrk
trkfrk's Avatar
Good Luck
Thanks! I bought the solvent at Harbor Freight.
Old 10-05-2010, 07:53 PM   #4
dmwphoto
dmwphoto's Avatar
that is going to be nice!
dmwphoto is offline   Reply With Quote
Old 10-05-2010, 08:55 PM   #5
68 short step
nice, gotta love those az cars/trucks
68 short step is offline   Reply With Quote
Old 10-05-2010, 08:59 PM   #6
jay6891
Car Knocker
jay6891's Avatar
It looks Killer!
I was thinking of that same combo, any thoughts on where or how that shifter is going to be inside. Guess running buckets is the only option.
Still looks Cool.... and Good Luck!
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 10-05-2010, 09:30 PM   #7
LEEVON
Moderator
LEEVON's Avatar
Originally Posted by jay6891 View Post
It looks Killer!
There's a kit to move the shifter forward about 5-6 inches, somebody here did a great write-up on it.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is online now   Reply With Quote
Old 10-06-2010, 11:10 PM   #8
trkfrk
trkfrk's Avatar
Great question!! something i was going to deal with later (buckets if i had to, prefer to stay with a bench). if you have info please let me know.
Hey Vegas guys.... Any C10 clubs around?
I will add pictures as I go. Thanks......
Old 10-06-2010, 11:59 PM   #9
chevy71c10
chevy71c10's Avatar
Hey trkfrk, Welcome to the board. Looks like a great build you have going, I'm doing a very similar build, exception is I'm using an LT-1 with 6 speed. Planning on using late model silverado buckets with integrated shoulder belts. Below are some links I found this week on manual/6 speed installations, one even from another forum about our trucks that includes lots of info. Keep the pics coming and good luck.
Justin
http://67-72chevytrucks.com/vboard/s...d.php?t=300892
http://67-72chevytrucks.com/vboard/s...d.php?t=386136
http://67-72chevytrucks.com/vboard/s...d.php?t=369833
http://www.ls1tech.com/forums/conver...-stepside.html
Justin
71' C10 SWB
00' Dakota R/T
05' Z-71 Silverado
16' Z-71 Silverado
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904
chevy71c10 is offline   Reply With Quote
Old 10-07-2010, 01:41 AM   #10
mcmlxix
Collector of Projects
mcmlxix's Avatar
Not sure if there are any C10 clubs.... I was trying to get some Pro-Touring types to meet the last Saturday of every month... Mostly Chevelle guys... We did good for a few months... then it just got too hot ... So I havent tried to keep it going.... It was at the Red Rock Casino .. Where in Vegas are you?
I'm doing an LS3/T56 swap into my 67 Chevelle... not sure I can be any help as its still in progress....
Rich
1972 K5 Blazer CST Click HERE
Old 06-08-2011, 05:58 PM   #11
belowme51
belowme51's Avatar
Should definetly put one together...my buddy has a 87 that he is building too. but would be cool cruising the strip all c10's!! nice truck btw. let me know if you need any help too.
belowme51 is offline   Reply With Quote
Old 08-09-2011, 12:01 AM   #12
chase1873
chase1873's Avatar
It looks Killer!
not much help as far as shifter position, but I came across a fellow who used a 4wd floor pan to give the 6 speed proper clearance. Ill re-post if I ever find the link.
Mike
1970 C10 swb step side... needs everything.
chase1873 is offline   Reply With Quote
Old 08-09-2011, 06:46 PM   #13
trkfrk
trkfrk's Avatar
Please let me know what you find. I haven't tackled it yet.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
Old 08-10-2011, 07:01 PM   #14
67cheby
67cheby
67cheby's Avatar
could you just switch in the High Hump bolt in part and have the clearance you need ?
67cheby is offline   Reply With Quote
Old 03-18-2012, 10:39 AM   #15
bovey
bovey's Avatar
Very nice build. I was they guy mentioned above who used the 4WD hump (or BBC hump) with my LS/t56 swap. It will give you loads of room and is a very easy option.
Also, if you want to run a bench with the t56 you can - I did. You just have to find a shifter that is bent right. I happened across a factory '68 b-body mopar shifter and it worked perfectly. I raised it 1" tho.
Again, nice work. You're going to love it.
bovey is offline   Reply With Quote
Old 03-18-2012, 03:51 PM   #16
trkfrk
trkfrk's Avatar
Thanks to your help, I did use a high hump. I modified it for the new shifter location.
Working on the bed now. Soda blasting is complete. I would not recommend doing this in front of your house like I did.
Mark
Old 10-05-2010, 08:59 PM   #17
mjensen
mjensen's Avatar
You'll have to keep us posted. I would really love a 6-speed in mine, and have been wondering how big of a project it is.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 10-05-2010, 09:50 PM   #18
Pop's C-10
Pop's C-10's Avatar
nice start
Pop's C-10 is offline   Reply With Quote
Old 10-05-2010, 10:11 PM   #19
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
my 1st frame off too. I am also doing a genIV 6.0L carb'd LSx conversion but will be running a 200-4r
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-05-2010, 11:30 PM   #20
nyncompute
nyncompute's Avatar
Fellow Las Vegas guy here. Show lots of pics of the build!. I would love to do one up like your doing. Good luck
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 10-06-2010, 08:39 AM   #21
mcmlxix
mcmlxix's Avatar
Welcome from another Vegas member...
Rich
Old 10-06-2010, 11:12 AM   #22
pockets
pockets's Avatar
welcome to the board. I moved from vegas last summer. wish I was still there
Love the powertrain combo!
Project Bad Karma
pockets is offline   Reply With Quote
Old 10-06-2010, 12:55 PM   #23
big_al_71
big_al_71's Avatar
nothing like a chassis all ready to be stripped!!!!
keep the picts coming
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-06-2010, 01:26 PM   #24
Number98
Prestige Worldwide
Number98's Avatar
Agreed....
Number98 is offline   Reply With Quote
Old 10-07-2010, 09:25 AM   #25
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I drove that combo in a Camaro; it was sweet. You going to freshen the motor?
Tom Vogel is offline   Reply With Quote
