Old 10-07-2010, 07:54 PM   #1
lo72
Truck Junkie
lo72's Avatar
C Notch help
Any tips on putting a c-notch on my 85 C-10 The kit is a doetsch from jeff at CPP. The instructions state they are left and right and the long ends go to the front of the truck. Mine look to be identical length, width etc. The bolt holes line up exactly with each other...pics would be great
lo72 is offline   Reply With Quote
Old 10-07-2010, 09:04 PM   #2
SCOTI
SCOTI's Avatar
Re: C Notch help
Pics would help us as well.... Show us what you're working with.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-07-2010, 09:39 PM   #3
lo72
Truck Junkie
lo72's Avatar
Re: C Notch help
Here are some pics. The instructions say to inatall the flip kit, then mark the axle center and center the notches on the center line. Both notches are identical
Old 10-07-2010, 09:48 PM   #4
SCOTI
SCOTI's Avatar
Re: C Notch help
Generic instructions most likely.
Lift the axle to the frame.
Mark the edge of the housing tube. 1.5" from that mark will be the centerline of the axle @ that drop amount.
Measure & mark the centerline on each c-notch.
Take the c-notch, & make a cardboard template of the notch area that gets cut out (including the centerline reference mark).
Align the C/L of the template you make w/the C/L of the axle mark you put on the frame earlier.
Trace the template & that's your initial cut.
Grind to fit from there.
*Use a drill bit for your corners & cut straight to the holes drilled. Rounded corners = less possibilty for stress related cracks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-08-2010, 07:47 AM   #5
lo72
Truck Junkie
lo72's Avatar
Re: C Notch help
Thanks Scoti, your tips will make this a easy weekend project
Old 10-08-2010, 10:36 AM   #6
HumbleChevyBuddy
HumbleChevyBuddy's Avatar
Re: C Notch help
Where exactly did you get this kit and what was the price? I'd like to purchase the same exact one for my truck. Thanks!
Fernando
Project "FATBOY" build thread
The key to happiness is having dreams. The key to success is making your dreams come true.
HumbleChevyBuddy is offline   Reply With Quote
Old 10-08-2010, 10:38 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: C Notch help
....The kit is a doetsch from jeff at CPP. .....
CPP is a forum vendor and CPPJeff is our forum rep. Hook up with him and he will take great care of you.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-08-2010, 10:42 AM   #8
lo72
Truck Junkie
lo72's Avatar
Re: C Notch help
I got it from Jeff, I think it was about 650.00 for all c-notch ,flip kit,spindles,springs and a pair of spring shackles and 4 shocks
Old 10-08-2010, 11:03 AM   #9
HumbleChevyBuddy
Re: C Notch help
Talk about a HOOK UP! Just PM'd Jeff. Thanks for the info...sorry to jack your thread.
Fernando
