Old 10-08-2010, 10:45 PM   #1
stich626
Question blazer tank in a p/u
! have a 71 c-10 that I have a blazer tank kit for (underbed)
best place to put the filler .don't want to cut into the bed sides?
stich626 is offline   Reply With Quote
Old 10-08-2010, 11:18 PM   #2
72smoker
72smoker's Avatar
Re: blazer tank in a p/u
Can you put it in the wheel well of the rear tire or bring it up through the bed floor? I don't know where else it can go.
72smoker is offline   Reply With Quote
Old 10-09-2010, 12:01 AM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
backup light, pass. side..
John
1999 Toyota Tacoma 4x4
Old 10-19-2010, 10:23 AM   #4
stich626
I like that, shoebox like,
Old 10-09-2010, 08:34 AM   #5
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I put mine in the wheel well.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-11-2010, 08:25 PM   #6
chuck3026
chuck3026's Avatar
It depends on if you drop the truck and your wheel size as well. Mine has a 5" drop with 20's out back and she hugs the fender so no chance to put the filler in the wheel well. I've seen the side marker scenario but I chose to do the trap door in the bed floor....good luck
2006 Crew cab Z71
1972 Short Wide Step (under construction)
chuck3026 is offline   Reply With Quote
Old 10-19-2010, 10:54 AM   #7
LeatherMan69
i plan on taking mine up through the stake pocket. in the rear driver side, we'll see how that works tho.
LeatherMan69 is offline   Reply With Quote
Old 10-19-2010, 12:12 PM   #8
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
thats how i did mine. worked out great! got the idea from John Fabris
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 10-19-2010, 12:22 PM   #9
John Fabris
TOTY 2006
John Fabris's Avatar
Thumbs up Re: blazer tank in a p/u
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 10-19-2010, 03:57 PM   #10
stich626
Originally Posted by John Fabris View Post
nice but my long bed sides are not that wide.. did you reform the top of the rail
Old 10-19-2010, 01:23 PM   #11
LeatherMan69
John That is AMAZING love it, you just solidified that idea for me... You are a true artist
Old 10-19-2010, 01:48 PM   #12
72mike
I am looking to do this conversion but heard you cannot run a hidden hitch receiver with the blazer tank. Does anyone have any info on this? i really want the extra gas and extra space inside the truck. But do not want to loose my towing capabilities.
Mike
72mike is offline   Reply With Quote
Old 10-19-2010, 02:37 PM   #13
John Fabris
TOTY 2006
I have the early classic hidden hitch with mine, and while space was tight for getting in there with tools, it is doable. I have a rear tank from an early suburban, which is not much different then the blazer tank. I also used the flip down license plate holder. All works with no issues.
John
John Fabris
67 C10 SWB
Old 10-19-2010, 02:43 PM   #14
vasquezmrysvll
"the other guy"
my tank is from a 76 van, i don't have a hitch but there is plenty of room if i wanted to add one.
Old 10-19-2010, 02:55 PM   #15
72mike
Thanks for the imput, just what i needed to hear. If anyone has a suggested brand that they have used for a relocation kit, please share....
Thanks Mike
Old 10-19-2010, 03:03 PM   #16
vasquezmrysvll
"the other guy"
i pieced mine together with help of the local wrecking yard. got the filler off ebay.
Old 10-19-2010, 03:02 PM   #17
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
John, that is freaking awesome! Can you tell us where to get the fill tube and gas cap you used? I'd like to do that to my Longhorn.
Ryan
1969 Chevy milk truck
Old 10-19-2010, 03:51 PM   #18
Dieselwrencher
Do you have a link for it? Thanks.
Ryan
Old 10-19-2010, 04:16 PM   #19
Dieselwrencher
Stitch, you should have this same area, except your stake posket is more than likely stock and his has been welded shut and had this filler installed in it.
Ryan
Old 10-19-2010, 04:23 PM   #20
stich626
ok looks bigger in the pic for some reason..
maybe he can give up the vendor for the cap set up
Old 10-19-2010, 04:29 PM   #21
sandnuriz
sandnuriz's Avatar
My brother did the same thing but used a flush mount from a Harley tank they are every where and really cheep
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Old 10-19-2010, 05:00 PM   #22
John Fabris
TOTY 2006
The top of the bed side is still stock, other then I removed the stake pocket and with the new filler, it is much larger then the stake pocket, so I cut the filler housing down to fill the retangular hole.
here is some more info in this link
http://67-72chevytrucks.com/vboard/s...d.php?t=211579
So, other things you will need to do this are:
1. fuel filler hose (from any parts hose, this is not little fuel line, this is the hose for filling Gas tanks.
2. a section of steel tubing or SS tubing bent into a 90 degree from any muffler shop.
3. the Gas fill assembly that you can get for motorcycles or boats (Hint, boat shops have these for around $50).
The only other real mods is to remove the pocket of the stake pocket (hammer and chisel to knock out spotweld, and then at the bottom of the pocket, you will need to cut some clearance for the 90 degee pipe to fit in.
Yea, its pretty fun when people that see it, ask why only 1 tie down on your bed? uhm, that is my gas fill. It is funny to see when I am filling it up. standing at the back of the bed the the gas hose. No one has really said anything to me other then the doubletakes. I am sure that if my wife was seen filling the truck, some guys would call her a dumbblonde not knowing that she really is filling up the gas tank.
John Fabris
67 C10 SWB
Old 10-19-2010, 05:11 PM   #23
Dieselwrencher
Thanks for the info. I appreciate it. I have been on the fence on leaving my tank in the cab on my Longhorn. Not now, it's going bye bye and I'll put a tank or 2 under the box. Great idea!
Ryan
