Old 10-09-2010, 01:45 AM   #1
hoodrat
crossmember swap '64 into '60
hello, first post here. lots of good info here but i still can't find what i'm looking for. i scored a '64 front end for $40 and put it into my '60. i got 2 bolts per side to line up (the front lower frame bolts) and thats it. now before i start oblonging and drilling holes in my frame can someone tell me if these are the right holes to index the others from? i thought i saw a post somewhere about this but can't find it now. thanks in advance. mark
p.s.- its going to be bagged and very low
hoodrat is offline   Reply With Quote
Old 10-09-2010, 06:13 AM   #2
raycow
Re: crossmember swap '64 into '60
If it were mine, I would make sure the wheels were centered in the fender openings and not worry about which holes line up.
Ray
raycow is offline   Reply With Quote
Old 10-09-2010, 08:19 AM   #3
scotts62
One day...
scotts62's Avatar
I put a 74 cross member in mine and had to drill the frame for it to work and do like raycow said then punch some holes and you should be good.
Scott
93 crew cab build
Project 62
