Old 10-09-2010, 01:51 PM   #1
samdjr74
Steering/header issue again, need help
Hi All,
So even if I use a 3 joint steering system the headers are going to be in the way. One I think I need to find is a longer header that's also a hugger, does anyone know if this exists?
Thanks,
Sam
samdjr74 is offline   Reply With Quote
Old 10-09-2010, 01:53 PM   #2
Dan Bowles
AD Addict
Re: Steering/header issue again, need help
On what?
Dan Bowles is offline   Reply With Quote
Old 10-09-2010, 01:58 PM   #3
samdjr74
sorry, it's a 350 in a 56. I'm running a TCI custom IFS that uses a rack and pinion. the 350 is in the same location as where an original V8 would have been.
Originally Posted by Dan Bowles View Post
On what?
Old 10-09-2010, 03:13 PM   #4
Tchia65
Can you post a picture so we can see what you're seeing?
1958 Fleetside shortbox
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Tchia65 is offline   Reply With Quote
Old 10-09-2010, 03:28 PM   #5
samdjr74
HYere's a pic I took the other week. You'll notice the u joint isn't on but the problem is the collector of the header is tight in the middle of the steering shaft path as well as the u joint is almost touching the collector at the same time
Old 10-09-2010, 03:36 PM   #6
pro1955
pro1955's Avatar
I used the 2/3 length headers, several companys make em. You won't have that problem they flow back not so much center drop.
Truck's just for the fun of it.
pro1955 is offline   Reply With Quote
Old 10-11-2010, 01:43 AM   #7
nikwho
nikwho's Avatar
What does TCI reccomend? Surely they have already figured this out. I used a set of Heddman headers 2/3 for a 70-81 camaro, but I grafted a '79 Camaro sub frame on mine and its a bit different.
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 10-11-2010, 09:42 AM   #8
samdjr74
TCI didn't help much, they basically said all builds are going to be different and they can't confirm that fitment problems may or may not happen.
Old 10-09-2010, 03:43 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
You can use 4 joints. You just need to use 2 heim joints to stabilize the shaft.
Yellow are Ujoints, red is the shaft, and green are heim joints. get a wooden dowl and duct tape and work out the angles
Old 10-09-2010, 03:55 PM   #10
samdjr74
It's not the u joint, it's the angle, even adding a forth would not help as the angle coming off of the joint on the rack needs to be 45 degrees just to clear the header
Old 10-09-2010, 03:55 PM   #11
bobinbc
bobinbc's Avatar
Would something like this work?
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 10-09-2010, 03:57 PM   #12
samdjr74
I was thinking of that but not sure if my steering column would get in the way
I noticed that Edelbrock makes something but at $400+ it's a little too much
Old 10-09-2010, 05:05 PM   #13
pro1955
pro1955's Avatar
bobinbc shows a pic of what I'm talking about Patriot makes em, great quality. I bought mine through a vender at a swapmeet for 275 coated inside and out.
Old 10-09-2010, 07:24 PM   #14
entourageguy
Yellow truck club
entourageguy's Avatar
s10 v8 conversion headers work fine in my 59. 3/4 length.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 10-10-2010, 09:24 AM   #15
samdjr74
Hi all,
Thanks for all of the input. Before I order another set of headers I took some more pictures last night. I think the root problem is my current headers don’t get close enough to the block. Is it worth it to try and find a set of huggers that just come in closer? Also if I do go with the mid lenght style headers does anyone se any issues with clearance between the block and the column?
Thanks,
Sam
Old 10-11-2010, 10:12 AM   #16
mr48chev
mr48chev's Avatar
It looks like a set of headers for a 67/71 Chev truck would work also. I have a set of the Joe Cheapies from O'Reilly's on my 71 and they fit quite well.
Looking at the top photo it looks like the steering column sticks down through the firewall a lot further then it could. That puts a lot of unnecessary angle on that universal joint.
Old 10-11-2010, 11:27 AM   #17
samdjr74
It does stick out a little too far but for some reason that's the column that was lissted for a 55-59, the angle isn't that bad at all so I think it will work.
I'll look into the 67-71 headers, thanks!!!
Old 10-11-2010, 01:16 PM   #18
nikwho
nikwho's Avatar
A couple of thoughts.
1- Can you shorten your steering colum? If it was a couple inches shorter it may buy you enough room to open up some options.
2- I bet an old set of ram horns would work well for you
'68 GMC - BBC/TH400
Old 10-11-2010, 04:23 PM   #19
samdjr74
I can probably cut a few inches off of the bottom, there's plenty of meat there.
I was thinking of going the ram horn route, I also found a couple other headers by patroit that might work, they kind of resemble ram horns which might work for me.
My other issue is I have angled plugs so getting a set of headers that fit with everything is becoming a challenge.
Old 10-11-2010, 01:20 PM   #20
nikwho
nikwho's Avatar
[QUOTE=samdjr74;4235054]It does stick out a little too far but for some reason that's the column that was lissted for a 55-59, the angle isn't that bad at all so I think it will work.
QUOTE]
Could that column possibly be for a factory 55-59 steering box? Classic parts sells a bearing that slides into your shortened column and supports the steering shaft.
http://www.classicparts.com/1947-59-...ctinfo/76-987/
'68 GMC - BBC/TH400
Old 10-11-2010, 04:25 PM   #21
samdjr74
It's not long enough for that, atleast it wouldn't reach ll the way to the stock steering box on the frame
[quote=nikwho;4235184]
QUOTE]
Old 10-11-2010, 04:27 PM   #22
nikwho
nikwho's Avatar
Man, good luck! I hope you get it figured out!
'68 GMC - BBC/TH400
Old 10-11-2010, 07:07 PM   #23
floridasteve
floridasteve's Avatar
This is what I had to do on my truck. I had the same issues but it looks like your headers are longer than mine. These are on a truck I saw in Daytona to give me a reference and mine is the same. It worked like a charm. I had to make it work but it is fine now. I hope this helps.
Just my two cents but it looks like your steering is a little farther out from the firewall and the headers look longer than most shorty headers.
One day I am going to finish this project!
1949 Chevy 1/2 ton
floridasteve is offline   Reply With Quote
Old 10-11-2010, 07:08 PM   #24
floridasteve
On the kids mac and thought that I had them resized. Sorry, I will repost when the show me how. Sorry!
1949 Chevy 1/2 ton
Old 10-12-2010, 01:25 PM   #25
samdjr74
I just ordered another set of headers, hopefully my last
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
I think these will fix the problem. Right now I have 2 main issues:
1. The current headers stick out from the block a little too far causing it to get in the way of the steering
2. The collector flange needs to be either higher or lower as it's forcing the u joint to be pushed beyond the 38 degree limit
If I'm right this should correct these 2 problems
