10-09-2010, 09:31 PM | #1 |
need a rear end
so this C30 i have been looking at is not so good in the cab section. and i dont need another junk cab parts truck...What i do need is the rear end.
I want the narrow dually rear end. I will end up boxing my C10 frame and slapping that bad boy under my 127" frame and rolling with it. Any one know of a stash pile of such rear ends? What is there specific name? are they Dana 60s or 70's, 12 bolts or 14 bolts....all i know is that its an 8 lug narrowed dually and i want it! oh and how do i convert my 5 lug C10 front discs to 8 lug discs |
10-09-2010, 10:21 PM | #2 |
its all about the +6 inches
Re: need a rear end
the narrow rear, is actually the same as a normal rear.
The rear in the one ton is the Corperate rear with an eaton diff. We usually call them Eaton HO72 on here. I don't recomend getting one. a lot of parts are hard to get, like drums. You can get a 14 bolt rear out of a 73 and newer truck. Any cab/chassis later model truck, or a single rear wheel C/30 will do. (if you don't plan on the heavy loads, then a 3/4 ton will do) To do the front, the easiest way IMO is the swap out the whole front corssmember, hub to hub, with a c/20 or C/30 truck. |
10-10-2010, 09:45 AM | #3 | |
Still plays with trucks
Re: need a rear end
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
