Old 02-28-2003, 12:16 AM   #1
70cst10_05
70cst10_05's Avatar
cab corners
What do you guys think the best way to put a cab corner on??Use the whole aftermarket piece or just cut away the old rust and cut the new panel to fit???pictures welcomed, haha.any and all help appreciated.
thanks
kevin
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
1972 Chevy Suburban K/10
2019 Silverado 2500 Duramax
Kevin
70cst10_05 is offline   Reply With Quote
Old 02-28-2003, 12:34 AM   #2
pissonNOS
senior member
pissonNOS's Avatar
do the whole panel
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 02-28-2003, 12:58 AM   #3
adamls
Gotta Startem Early
adamls's Avatar
The very best on this board (ebfabman) reccomend just replacing as much as you need. Most aftermarket pieces do not line up correctly. Just replace what is rusted.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 02-28-2003, 01:08 AM   #4
pissonNOS
senior member
pissonNOS's Avatar
true enough, I must say tho i had the best luck wiht my napa parts to each his own
69 GMC bagged
Old 02-28-2003, 01:14 AM   #5
bigvinnie
bigvinnie's Avatar
cut the rust back on your existing cab corner and then trim the new cab corner to fit.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 02-28-2003, 01:31 AM   #6
hobby67stepside
Yes, the smaller the amount you have to patch in the better.
  • '05 2500 HD Silverado 6.0 liter
    '97 2500 4X4 454 eng
    '92 2500 4X4 350 eng
    '78 K20 4X4 400 eng
    '70 Boss 302 (owner for 27 years)
    '57 Ford shortbox 383 stroker TH350 tranny
    '23 T-bucket (built in '78)
    '02 Explorer
    '67 C-10 short step
NW Iowa
hobby67stepside is offline   Reply With Quote
Old 02-28-2003, 09:56 AM   #7
kaycee
kaycee's Avatar
Warped
I used just what I needed and it warped on me if I was going to do it again I would cut it at the line or seam.I was told that u can blend your weld better this way.The way I did it caosed it to warp but nothing a little filler won't take care of.I am by no means a body/ paint man just the average do it your selfer I know when to say when.Hope this helps just my experiance
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 02-28-2003, 10:54 AM   #8
jay6891
Car Knocker
jay6891's Avatar
I always try to leave the original body lines. Just cut out what is rusted. Have you remove the rocker? On my truck, it seemed to put together from the factory back to front. By the time I got the cab corner cut, I found more rust. Ended up pulling the whole side of my truck down., to get all of it. I knew I would eventualy have to do it. Just not all at once.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 02-28-2003, 10:57 AM   #9
jay6891
Car Knocker
jay6891's Avatar
couple of more of what I had to cut out. Also had to replace front cab mount. Sucked doing this outside. Fought surface rust until I got it primed with Eastwoods rust inhibiter.
Old 02-28-2003, 10:59 AM   #10
jay6891
Car Knocker
jay6891's Avatar
back together, although not primed yet
Old 02-28-2003, 11:10 AM   #11
dubie
dubie's Avatar
Here's mine right now. I am using the entire patch on this one. Looks like I need some new cab supports too.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 02-28-2003, 02:35 PM   #12
hobby67stepside
I had to rebuild this whole rear cab support piece (shown here upside down relative to its position when installed).
    '78 K20 4X4 400 eng
    '02 Explorer
    '67 C-10 short step
NW Iowa
Old 02-28-2003, 04:34 PM   #13
1971Stepside
Almost Satisfied
1971Stepside's Avatar
hobby, do you have any more pics of that? I need to rebuild mine as well and was wondering how you took it out and what you did to the floor above it.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-28-2003, 05:39 PM   #14
Southpa
Southpa's Avatar
Use what you need. Here are some step by step pics of how I did mine.
http://groups.msn.com/Alsplac/corners.msnw?albumlist=2
Now is a good time to work on rear cab supports if needed. I can't think of any other way to replace rear supports with the corners still on.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 02-28-2003, 06:12 PM   #15
EdB
I replaced mine a few years ago. The aftermarket fit was
so poor that I had to replace the part that was rusted.
I managed to find NOS rocker panels and they went in like
a breeze.
NOS is rare so I guess we are stuck with doner panels
(rare on cab corners) and aftermarket.
I have some panels that look good for my drivers door. They
are from Rolling Steel. I haven't tried them yet.
There seems to be a lot of difference in the manufacturing
process from original and aftermarket.
I guess my question is what is the best source for aftermarket?
EdB
EdB is offline   Reply With Quote
Old 02-28-2003, 06:26 PM   #16
70chevy
70chevy's Avatar
Do a search
Do a search on Cab corner replacement and alot of good info comes up along with panel replacement.
Ken Smith
99 C5 Torch Red Coupe
85 Chevy Candy Apple
70 Chevy 1/2 in process.Semi-gloss black powdercoated frame & suspension, disc brakes up front, 3" drop spindle(Beltech) 5 lug 3.73 rearend, ZZ4, Sanderson headers, 700R4, Air Ride system, Summitt 16 gal fuel cell, Holly mech. fuel pump,
70chevy is offline   Reply With Quote
Old 03-01-2003, 09:53 AM   #17
hobby67stepside
1971 Stepside, I do have a few more pics of this piece, but I'll have to find them and scan them into the computer. I'll try to find them and do that if you still want to see them. To remove that main piece I had to drill out about 70 or 80 spot welds. The outriggers were almost completely rusted away where they attach to the support piece so I didn't have to fight them in the removal process. I then cut pieces of plate steel slightly heavier than the original and just slowly rebuilt it. At the ends I did use the after market outer cab support pieces and even re-inforced them. I went slow and checked measurements all thru the rebuilding process - took more hours than I care to think about. I've been on this board over a year and have never seen posts from anyone else who has done this. I don't think my cab was rusted worse (I know it wasn't 'cuz I have seen pics here of much worse ones) than most. I just wanted to rebuild as solidly as I can. Hope this helps and if I see a reply I'll get those pics on. One other thing - when reinstalling I used some fairly heavy angle iron pieces to fill in where the outriggers were rusted away. I kind of just had to figure that out by the seat of my pants, but it did come together.
    '78 K20 4X4 400 eng
    '02 Explorer
    '67 C-10 short step
NW Iowa
