10-13-2010, 08:59 AM | #1 |
78K & 79C Jimmys
Np203
not sure if my tcase was changed from full time to part time 4x4,some kinda kit for this?
what i read is: if the front has man hubs,may have been converted? seems like i need to play in the sand or snow to find out any other way? also the support bar is gone MIA from the bell housing to the transfer case guess someone forgot to put it back?guess i should use the one from the burb
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
10-13-2010, 11:05 AM | #2 |
Windy Corner of a Dirty Street
Re: Np203
One way to know if the truck hasn’t been converted is by the fact the truck will not move if the hubs are Unlocked. At least that is the way my ’78 K10 was when I first got it. It did not have the part time kit but did have lockouts. It would not move until the hubs were locked in.
The 205’s didn’t use a support rod like the newer aluminum cases did. The bosses in the 205 are old left over castings from when they did use a small bracket that attached to the frame on earlier trucks. I think ’69-’72. Eventually, GM quit using the side bracket as it was not needed on the 205.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
10-14-2010, 08:47 AM | #3 |
78K & 79C Jimmys
Re: Np203
and the 203 and 205 work the same?
10-14-2010, 07:06 PM | #4 |
Re: Np203
Well…… yes, no, sorta, kinda, not really??
Both split power and both have Neutral and low range but that I about where the commonalities end. Operationally, they both work basically the same if a 203 has a part time kit.
10-14-2010, 08:36 PM | #5 |
78K & 79C Jimmys
Re: Np203
thanks; it seems to be as the hubs are undone and the front drive shaft spins
10-15-2010, 06:47 AM | #6 | |
Re: Np203
Then it has been converted to "part-time" with a kit.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
