hey fellas..came across a smoking deal this past weekend on a 74 4wd jimmy all original with running 350 sbc (89,000 original miles). the 4wd look is okay to me, but have become more of a lowered guy myself, as i already have two 4wd vehicles in the garage. i know some may call it a sin, but is it possible to convert the 4wd yimmy to a 2wd? and how big of a prob would it be??
Jonny
Re: 4wd Jimmy to 2wd Jimmy?
I don't know about switching the 4wd frame to 2wd, but I do know that I came across this on craigslist a few days ago. It seems to be the easiest answer to your dillema
http://austin.craigslist.org/pts/1991211750.html
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
#3 | |
I know the pieces fit
how low you want to go? you could z the frame and cut the front off a c10...
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
something kind of mild..possibly just a 2-4 or maybe a little more. i thought about the same. just finding the front end out of an old c10 somewhere, i actually picked up an old c10 the other day for nothing(just hauling it off a guys land). but didnt know what all i'd have to do to convert it..
Do yourself a favor and just get a 2wd frame or complete truck. It will be too much work IMO when you can pick up something that's already been made from the factory.
86 Suburban 2WD = rolled it and totaled it ![]() 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. ![]() 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
thanks for the link/advice guys..looks like that chassis could be calling my name. guess my next question would be, i know there prob cant be much difference, but have any of you guys had any experience doing the same? placing a Jimmy body on a K5 frame? or would i need to find another jimmy? (hate those technical questions)
should be the same frame.
big old burb in primer.lot of work to do. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Just add a 2wd crossmember to your 4x4 frame and use a flip kit on the rear.
No need to swap frames. If you can find a donor 2wd pickup,... that would be the best. You'll need the transmission, tranny crossmember, and other parts. You can even add aftermarket 67-70 6-lug disc rotors and keep it 6-lug so you don't have to change the rear axles. Or swap in the pickup 5-lug rearend also and make it 5-lug. I love the full top 73-75 blazers!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-14-2010 at 04:11 PM. |
see http://67-72chevytrucks.com/vboard/s...d.php?t=168231 for some details
I have a friend with a titled '81 2WD, body is junk but the frame is straight. I'll ask him what he wants for it, my guess is it can be scored for cheap. Then you can sell the 4WD frame you have to one of the guys that needs it.
Tags |
4x4 to 4x2, jimmy, k5 blazer, lowered |
