Grandpa in the rustmobile...
Which heater control cables go where?
Non AC, I did some searching but just came up with the electric wiring part
3 cables all diff. lengths Which ones go where? I had them where I think they were right but they were binding (oiled them good too?) And its not working but I forgot to ground the heater motor and check the fuse
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: Which heater control cables go where?
anyone? a pic of routing would be nice too?
The Older Generation
I posted info and pictures in this thread.... http://67-72chevytrucks.com/vboard/s...d.php?t=241369 LockDoc
I took my controls off and replaced them about 10 years ago and had the same problem so i got under the dash and turned on ther key then found all 3 control arms on the heater box, first i figured out which one turned on the fan, then i tryed the other two and figured out the one that routed the airflow from the heater floor to the defrost, then the last one is obviously the heat control. I lubed mine i think with Tri Flow, kinda pricy tho..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
what is 'tri flow'?
I think i figured out where they go...Its just that they dont like to move, maybe the cables are a lil bent on the ends, oh well i'll freeze tomorow (cold front) then get it sorted out that evening maybe?
make sure the levers move on the heater box ok when unhooked, then that the new control levers move ok without the cables bent as per the routing, if they do then you need to lube the cables better.
Its a lubricant.. its at most auto parts or even Walmart or Meyers ect.. http://www.triflowlubricants.com/Tri...Lubricant.html http://www.triflowlubricants.com/Tri...Lubricant.html
One of my cables was so frozen, the lever arm behind the control box was broken.
be careful when testing. Don't force it. I will try the Tri flow have some thanks
Ed F 1972 Sierra Grande White Top Medium Olive 402 bb / Camper Stock, Loaded, Straight & Aged Nicely, No Tilt Original Resto would be nice $ ![]() |
Yea thats why i had to buy a new control assy, it was in dire need of lubrication and then i busted a lever trying to move it. Its been a long time so i can remember if i used a motorcucle cable lubing tool or not, but if ya have one it couldn't hurt, just be sure to put down a bunch of rags to catch the excess if ya do it in the truck LOL! I'd recomend removing it..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 10-14-2010 at 12:20 AM. |
#9 | |
Will probably need to replace that box as well. Reminded me of a frozen steering cable on my first boat.
