Old 10-14-2010, 05:11 PM   #1
camaro41701
4 3/4 bolt pattern
I have a 72 C10 rear that has 4 3/4 bolt circle.The axles or drums have not been drilled.What is it?
camaro41701 is offline   Reply With Quote
Old 10-14-2010, 07:18 PM   #2
jibs
jibs's Avatar
Re: 3 3/4 bolt pattern
4 3/4 bolt circle is GM mid size 1950's thru 1980's, chevelle, camaro, skylark, 442, GTo etc. Easy pattern to get wheels for. JJibs
jibs is offline   Reply With Quote
Old 10-14-2010, 07:30 PM   #3
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
It was also used on S10s, Astros, and box Caprices ('77-'90).
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 10-15-2010, 02:51 AM   #4
foxhole
foxhole's Avatar
astro vans were 5 on 5 like the half tons and big cars.
foxhole is offline   Reply With Quote
Old 10-14-2010, 07:51 PM   #5
69 longhorn
if its a 12 bolt truck style rear, it could be from a late 60's/early 70's VAN. The early vans had a 4 3/4 " bolt circle. crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 10-14-2010, 08:52 PM   #6
camaro41701
Rear is out of a truck unless some of the vans were Trailing arm.The housing has never been cut or welded on.If this is a van.What 5 inch bolt circle axle would fit?
I want to use this rear in my truck because of ratio and the housing is real nice.
Old 10-15-2010, 02:06 AM   #7
raycow
Could it be a normal 12 bolt with aftermarket shafts? I believe you can order custom shafts with any reasonable bolt pattern.
Ray
raycow is offline   Reply With Quote
Old 10-15-2010, 03:11 AM   #8
69 longhorn
No, the vans were all leaf , & the ones I have run across have a smaller (Nova/Camaro) drum setup. It could be as already mentioned, aftermarket axles. Just a ? tho.....when you measured the bolt circle, did you measure from center of 1 stud, the the "imaginary center" tween 2 studs directly opposite of the 1st one? Im not trying to be goofy, but if you measure from 1 stud to the next one that is farthest away.....you measure will come up about 1/4" short crazyAL
Old 10-15-2010, 07:40 AM   #9
LONGHAIR
Re: 4 3/4 bolt pattern
69 longhorn is correct, many times this is mis-measured.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
