10-14-2010, 05:49 PM | #1 |
So I started my truck this morning and its on 7 cylinders....
Woke up, got dressed, hopped in the truck to go to school, and thats when it hit me, sounds like it in constantly hiccuping (<--- If that makes sense), So far I have sanded down the cap, and the rotor, checked all the plug wires. and no luck, tommorrow i'm going to check the timing, replace points and condensor, and if that doesn't help take out my plugs and maybe do a compression test.. and this is the funny part about this once I got to school and realized how bad it was missing. I threw it in park and gave it about a 1/8 of throttle and after the motor hit the peak RPM and was coming down I heard some metal hitting each other, it happened three times back to back. has not happened since though. Any input guys? thanks in advance!!
73 Chevy k10 In progress http://67-72chevytrucks.com/vboard/s...52#post3552552 2000 Trans Am, ls1, 6 Spd http://ls1tech.com/forums/appearance...years-old.html |
10-14-2010, 06:36 PM | #2 | |
Re: So I started my truck this morning and its on 7 cylinders....
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
10-14-2010, 11:01 PM | #3 |
Not yet thats why I'm pullin the plugs, which im gonna end up doing in about 10 min ha,
10-14-2010, 07:54 PM | #4 |
MOTORHEAD!
I may be wrong, but I had a similar situation when I completely wiped out two cam lobes on my old 350... My .02...
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
10-14-2010, 11:02 PM | #5 |
If that is the case I will be stoked and super bummed at the same time. Stoked to upgrade the cam, Bummed to spend money...
10-14-2010, 11:07 PM | #6 |
I had an old 454 that only ran on 7...the intake valve was stuck open for some reason. I drove a couple thousand miles like that.
10-15-2010, 12:38 AM | #7 |
Ha I really hope a spark plug failed or something I don't care its my daily driver and I need it!!
10-15-2010, 01:35 AM | #8 |
If you have headers you can easily see which cylinder is missing by spraying some water on them. The missing cylinder won't make the water evaporate as quickly. Once you find the cylinder that's missing, do some basic checks. Make sure the plug wire is good, isn't burned, both ends are firmly attached, etc. Make sure the plug isn't broken or corroded. All the basic stuff. If all of that looks fine, then you can look at the rockers and valves to see if anything is amiss.
If you've got stock manifolds, the water test doesn't really work. |
10-15-2010, 01:51 AM | #9 |
Headers FTW! ha glad I have them will go try that in about 5 mins Thank you!
10-17-2010, 02:13 AM | #10 |
So it was either my points or condensor replaced both and is runnin like a champ!!
