Old 10-15-2010, 12:10 AM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Broke the seatbelt bolt!!!
I was removing all of the interior in my 82 and the hardest bolts to remove were for the seatbelts. It was almost like they had been loctite'd at the factory! Anyways, I broke the drivers side bolt off. I soaked it with a bunch of release-all for three days straight just praying that when I went to drill through it that it would catch and spin out. It didn't!!!!! What should I do? Use an easy-out and try to pull the bolt out, or drill it to the correct size before re-tapping to 12mm??
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 10-15-2010, 12:19 AM   #2
ratty 46
Re: Broke the seatbelt bolt!!!
Drill the bolt out in steps until your almost at the total bolt size. If you don't drill off center you'll be able, with a punch or like drift, cave the sides in making it a "shell" of its former self. Once you've collapsed it you be able to pick it up with a needle nose pliers.
Whilst at GE, working Power Gen repairs, if I had a nickel for every 4" bolt we shelled out I'd have a lot of nickels!
Good luck & use good quality drill bits.
Ratty 46
ratty 46 is offline   Reply With Quote
Old 10-15-2010, 10:23 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
iagree with ratty drill it out at the center and get it as thin as you can then id use the easy out.. ive done this a time or two myself on the seatbelt bolts too
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-15-2010, 10:55 AM   #4
babyJay
Arrived on a Pale Horse
babyJay's Avatar
I didn't have any luck drilling the one on my old 30 when I gutted the interior. I didn't have any bits decent enough to drill the hardened bolt, and burnt up several cheap ones I had laying around. Finally took a Unibit and made a hole right next to it, keeping it within the factory reinforced area (thicker than just the floorboard). I used washers and a nut on the bottom tack welded to the underneath.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 10-15-2010, 02:27 PM   #5
old Rusty C10
not to change the topic or hijack the thread but dont you just love those torx head bolts they use for this application on later years..... those always seem to strip.. Luckilly ive been able to use a dremel or frinder to make a hex head bolt out of it so that i can ratchet/socket it off
Bob
I hate cancer!!
Old 10-15-2010, 07:05 PM   #6
69GMC910
MOTORHEAD!
69GMC910's Avatar
Yeah, the middle two bolts were torx in my 82, and we had a 2 foot snipe on the torx key to get them out!!! Luckily they didn't strip! But I guess I'll just keep drilling my broken one bigger... I amazingly hit it almost dead center without even center punching!!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 10-15-2010, 07:52 PM   #7
tommys69/454
1969 short box
tommys69/454's Avatar
pull the carpet away. then drill it out under the thread minor. heat it up with a small propane torch, taking all the necessary precautions of coarse. then while still hot pound an easy out in it and back out the bolt. you only need enough heat to break the rust bond.
tommy morehouse
tommys69/454 is offline   Reply With Quote
