GoatLube Experss
![]() Join Date: Oct 2009
how low ?
I just got bout every thing to bag my Dually, I'm wonder'n how low it will sit with a basic "C" notch and 265/35/22 tire's ? I'd like to get 4" to 6" off the ground air'd out. If I have to I'll do big notch but would rather not have to do any mod's to bed floor .
Thanks Chris
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
Re: how low ?
i know some one with a bolt in c notch on a dually like yours and had to cut the bed out where the differential comes up so if you have to cut the bed floor anyway you might as well do a big notch. i want to say his frame was around 6 inches or more from the ground
1987 Gmc sierra 1962 Apache 10 |
Re: how low ?
oh by the way my truck lays frame on a 32 inch tall tire and my notch only sticks into the bed like 3 to 4 inches not sure without measuring but about that
It followed me home?
Re: how low ?
What do you plan on doing with the rear bag setup? I'm debating bagging my dually too and really dont want to mess with cutting the bed either. I might go with an air over leaf setup , cheap and simple.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#5 | |
GoatLube Experss
Re: how low ?
I will be home in Jan. for a few weeks and want'd to bag it then, but if I gotta mod the bed I wont have time, the bag's will have to wait I reckon. my goal is to be bout 4 to 6"s off the ground when air'd out , that way if I ever blow a line or a bag I can still drive home .
#6 | |
GoatLube Experss
Re: how low ?
I have several pictures of lower'd Dually' saved for insperatrion, yours is one of em ! thanks for the info Chris
Re: how low ?
http://www.fullsizechevy.com/showthr...ly+bag+projectt
heres a link to my build if i would have known better at the time. the bed floor is bolted in. just unbolt the whole floor and move it up then tack weld it back in. then get longer bed bolts and spacers then bam your done.
GoatLube Experss
Re: how low ?
Tyler, how big is your notch ? did it come from suicidedoor's ? the internet connection I have here wont let see the pictures in your biuld thread but I saved the link and will check it out when I get home in Jan.
I'm think'n I'll redrill and move the bed floor up bout 4" . do you still have the stock fuel tank's ?
#9 | |
Re: how low ?
Re: how low ?
What did you spend on that SD rear set-up & what size tires did you wind up w/for the front rear (I read in the thread where you got new fronts)? Drop spindles? Nice job BTW....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-16-2010 at 02:41 PM. |
#11 | |
Re: how low ?
the rear 4-link cost me $329 i think and the panhard bar was about 120. I have western chassis 3 inch drop spindles and i belive my new front tires are 29 inches tall. my other ones i had to beat the fire wall with a hammer and still they sat on the firewall when it was aired out
#12 | |
Re: how low ?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 10-16-2010 at 08:21 PM. |
GoatLube Experss
Re: how low ?
cochino12 does your truck have C notch in it now ? I just wanna be a little lower than your's when I'm air'd out . I went ahead and order'd an 8" notch from SD, but I'll probably cut it down so I dont have to raise the bed floor to much . I figure install the front bag's and level the rear to match the front.
3DrDwn--the 'burb not the band
Re: how low ?
Here's were mines at. Hope to be fitting the bed and draggin tomorrow. front is just set for the 16's for now but the rear will accomodate up to a 30" tire dia. for the inevitible switch to 22's. I built all the hard steel parts myself from scratch including all mounts, 4 bar, and watts link with nothing more than hand tools and a welder. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
#15 |
Re: how low ?
RunninLo do you have any more pics of how you set up the rear?
#16 | |
Re: how low ?
Still on the to-do list finish clearancing the x-member for the drive shaft,boxing inside frame to tie into the notch, rear shocks, and replace a blown out brake cylinder in the driver side which means brake job too, and fab a hidden style reciever hitch. also not sure why the bag mounts look tilted in this video but they are level. I had 4 different levels and a angle guage on this thing during the fab. Josh
#17 |
Re: how low ?
RunninLo
SWEET!!!!!!!
69 chevy stepside (project) ![]() 2006 Silverado Z71 Ext. cab ![]() 2005 Saturn VUE (wifes dd) |
