C10 CLUB Y QUE!
700r4 tranny
just had my tranny fix for burned up clutches.
i just got it back installed it and it wont change gears wondering if gov. would be an issue i also notice that when i did tighten down my torq convertor moved out away from tranny about half an inch or so would that cause the problem ill take a pic in a bit Last edited by Sick5; 10-16-2010 at 08:44 PM. |
#2 | |
Re: 700r4 tranny
C10 CLUB Y QUE!
Re: 700r4 tranny
yah i set the tv in the same place it was before.im just going to have to wait till monday
Resistance is Futile
Re: 700r4 tranny
Mine took many quarts to get it full.....not sure if it's there yet. How much fluid did you put in??
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Re: 700r4 tranny
11.5 to 12 qts fluid with new converter,is the flexplate on backwards? the raised pad for the converter bolts should face transmission.
60-66 Nut
Re: 700r4 tranny
If you set the TV cable where it was before that doesn't necessarily mean it is correct. Could that have been why your tranny burned up before? Correct TV cable adjustment and geometry is very critical on the 700R4's
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 10-17-2010 at 12:30 AM. |
C10 CLUB Y QUE!
Re: 700r4 tranny
flywheel broke and it pushed my torq out of socket when i was on the freeway.
thats why it burned the clutches up.i went around the block few times. and ajusted the tv cable in between. but nothing. i pull the the tv cable and it pulls it self back so that tells me that the tv is connected on the other side.. im also thinking my governor maybe took a ****. i really dont want to drive it too much im affraid to get the tranny to hot and burn it again.. if the pump is not pumping it wounded shift from revers to drive right? |
C10 CLUB Y QUE!
Re: 700r4 tranny
i put 11 qts
C10 CLUB Y QUE!
Re: 700r4 tranny
I've read you can blow air thru the lines to unstick watever is stuck
in the vavle body. I'm going to try this if it don't work I'm pulling out and off to the mechanic it goes Posted via Mobile Device |
1962 C-10
Re: 700r4 tranny
I recently put a rebuilt 700r4 in the '65. I believe it took 13-14 quarts to fill it.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
C10 CLUB Y QUE!
Re: 700r4 tranny
I talk to the tranny guy he said it might be the torq or just junk in the valve body?
Would the torq cause this? Posted via Mobile Device |
60-66 Nut
Re: 700r4 tranny
If there is junk in the valve body, either the builder didn't do a good job of cleaning the trans, or the trans cooling lines weren't flushed out prior to installing the new trans.
CLASSIX Truck Club
Re: 700r4 tranny
Hey Gilbert, let me know if you want me to swing by tomorrow to help you figure it out. I'm free all day.
C10 CLUB Y QUE!
Re: 700r4 tranny
I took it out. It's in the shop. I should have it back today. I'll let u know j.
Did you get yours up and running Posted via Mobile Device |
#15 |
C10 CLUB Y QUE!
Re: 700r4 tranny
Update:
mechanic said alot metal flakes and slug came from the torq convertor. 150 for another torq convertor. I will pick it up later on today and install and cross my fingers and hope it works Posted via Mobile Device |
#16 |
Re: 700r4 tranny
Dont forget to flush the cooler out so there is no 3rd times a charm! Good to see you have an answer.
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
#17 |
C10 CLUB Y QUE!
Re: 700r4 tranny
I flushed the lines last night. All I did was blow air till no fluids came out.
I want to go pick it up now and install it but I'm at work. Suck! Posted via Mobile Device |
#18 |
Re: 700r4 tranny
if you are having a problem there as the capt says, it should be flushed to get the crap out from everywhere. blowing air through just doesn't cut it. it is like trying to blow a rad out
you'll need a recirculating pump ron |
#19 | |
Re: 700r4 tranny
I would use more than air to flush that thing out, metal filings will cling to the inside, you need to get some coolant flush or just use some new tranny fluid and flush thru it..
My build thread: '66 Chevy |
#20 | |
C10 CLUB Y QUE!
Re: 700r4 tranny
#21 |
Re: 700r4 tranny
I dont know how much metal was in it but it wouldnt hurt to get some cooler flush, the stuff in the can, and run it through to make sure there is no metal hiding in it at all. I know what you mean by being stuck at work and wanting to work on something you have had on your mind for quite a while. lol. You will have it installed and running in no time!
#22 |
C10 CLUB Y QUE!
Re: 700r4 tranny
How would I Be able to clean out the torq convertor. Hate to spen another 150 or so when this one I have is still new
Posted via Mobile Device Last edited by Sick5; 10-19-2010 at 04:38 PM. |
#23 |
Re: 700r4 tranny
That isnt going to happen unless you can cut it apart and weld it back together, $150 is pretty cheap insurance if you ask me.
#24 | |
C10 CLUB Y QUE!
Re: 700r4 tranny
![]() Last edited by Sick5; 10-19-2010 at 10:54 PM. |
#25 |
Re: 700r4 tranny
from the shop to runnin on the hwy same day, you da man
